Wrong fluid in transfer case
Thank you for your opinion.
https://www.fuchs.com/de/en/product/...itan-atf-3353/
Which is superseded by Dexron VI from around 2005, which is what you should use....not because it's cheaper, but because it's better. It's licenced, with a proprietary additive pack, so even a generic WalMart Dex6 is the exact same as a GM dealer product or other licenced brands.
Don't worry about the residual gear oil, it's only slightly thicker than ATF, like 40 weight oil. No harm done, but the mechanic should re-do it at his or her expense.
https://www.slideshare.net/samcheng35380/lubrizol-atf
To put it in perspective, Dexron III used to come in cardboard cans. Mobil 1 is worth a shot.
https://www.walmart.com/ip/Super-Tec...Quart/52626198
https://www.autozone.com/motor-oil-a...art/930140_0_0
