Fuel pressure
Old Jun 22, 2021 | 02:20 PM
Talal Al Hadidi's Avatar
ML350 bluetec 2010. W164
Fuel pressure
Pls. I need to understand how to build high fuel pressure in fuel rails in engine OM642 while there is an open pipe to the return line to the tank ??
Old Jun 23, 2021 | 05:02 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
Scan for codes in fuel rail for Y74 and Y94.
Old Jun 23, 2021 | 08:36 AM
Thanks for your kind reply
I'm asked this because I removed the left fuel rail and see that the valve inside the rail not long enough to reach the return line I point with red in the attached photo
so this valve does not control the return of fuel to the tank 🤔
Old Jun 23, 2021 | 10:07 AM
Well then the part was probably installed by a [previous owner. You must buy you parts at a M/B dealer.
Old Jun 23, 2021 | 10:20 AM
Dear Sir
I think you mean that the parts is not properly installed by the previous owner ? , I compare it with another car like mine ( ML350 2010 , VIN
4JGBB2FB6AA593877 ) it's the same installation and same part no. !
am sorry to take your time but my problem still the same code P0087 fuel rail low pressure .
