Need new brake pads and rotors, OEM or alternative?
So wanted to know if there are any good alternative brands I can put on for pads and rotors versus OEM for my rear brakes.
On my E90 BMW I switched over to Zimmermann rotors ,which are the BMW brand, and Akebono pads. Works just as well if not better and less brake dust.
Does Mercedes Benz have an equivalent? Sorry doing some searching now as well.
I use Textar pads and Textar sensors in my car. No problems running in Brazil, Argentina, Uruguai and Chile for 120.000 Km, from Ushuaia to Amazon, sometimes in very very very bad roads. My rotors are Fremax, but you can use Zimmerman or ATE.
I've actually been looking into replacing my pads with Ceramic pads. Anyone have any experience with these, and what any pros and cons may be? I've heard they last a lot longer, some even have lifetime warranties? Details anyone?
Ya they last a lot longer , they also chew the livin $chit out of your rotors because they are rock hard
This is the kind of info I was wondering about. I see them often sold with new rotors as well, wasn't sure if there was something special about the rotors. Obviously didn't think they could be ceramic, so.... but this makes sense.. .have pads that last forever but tear the **** out of my rotors..probably not a great tradeoff....
It's this, you don't get something for nothing. if they last longer they are harder and wear your rotors. I typically change out rotors when hey look like they need to be cut or they are warped. You cut them once and hit one real hard stop, you will warp them every time. Either that or you have a raw egg taped to your brake pedal. If they are harder they could have a higher operating temperature, meaning you may have to nail them harder to make them work right, just wears your rotors faster. Just get factory equivalent replacements.
Tenaclubs (09-25-2021)
