ML550 2009, a/c troubleshooting compressor valve
My a/c was not working. I found a damaged o-ring that I have replaced. System evacuated and filled with the right amount of r134a.
After this everything was good for a while. The a/c then started to work intermittent. I suspect the valve in the compressor. I have the feeling when I regularly drive the vehicle, and it is not standing for more than 10h, the valve closes.
I also checked with a scanner. Refrigerant pressure is at 5bar when the engine is off, and goes to 6,5-7 bar when the engine is running.
Pwm duty cycle 100%, evaporator temp reasonable, same as the environment.
My next step would be to measure the Pwm signal at the valve, and have a new valve ready.
Would you agree to that, or is something leading also to a failed compressor? Pressure is rising minimal when the engine is running.
Also there is no leak, 100% sure. Had a vacuum on the whole night.
Thanks!
There is no fault code stored! According to the live data the pwm duty cycle should be 100%. I didn't manage to go below the car and measure it at the connector.
I appreciate any other comment like: continue to replace the valve, order directly a new compressor, sell the car...
I would use a scanner to find out.
How did you flush the system? Nitrogen?
And, with the old valve in hand - drill it out and put it back in place so the you can flush out the evaporator and lines all at the same time - and collect the nasty crap in a can in the engine compartment. I didn’t do that, and when flushing the evaporator coil the nasty wash went down the firewall - has taken several washings and two weeks for the chemical smell to go away.
You are amazing!!! Thanks!
final feedback: the valve was the issue. It was stucked and moved only a tiny bit. I tested it on the bench with an 12V power supply.
Getting the old out was a bit of a hazzle, I had to loosen the power steering hoses from the flange, and couldn't get them sealed anymore. So I drained this fluid as well, replaced o-rings and filled fresh fluid....
All works fine now.
Thanks to everybody! Awesome forum!
unfortunately I need to open this again. Here comes the thing:
The a/c was working for nearly a week now. This morning it stopped. I connected the tester iCarSoft and checked all the values. Refrigerant pressure at 10 Bar, compressor requested 100% no cool air.
I tried around a bit, and switched of the a/c, brought the engine to 2k rpm and switched back on the a/c. Then the valve seems to close and everything went back to normal.
What is your idea: Debris in the system? Voltage not sufficient to close the valve? (Voltage measured with 14,2V)
I dont know what I should do now, beside replacing all parts step by step (Which would be stupid)
Can somebody share with me a wiring diagram. I want to follow the PWM Signal from where it originated to the valve.
