What is the milage recommend to change my transfer case oil
Old Sep 5, 2021 | 03:17 AM
Mohammedusama's Avatar
W164
What milage recommend to change my transfer case oil !? And my 2nd question if my front tires need alligment this can cause my EPS not working !?
Old Sep 5, 2021 | 08:07 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
If you recently purchased the veh. you would not know if the previous owner maintained all the fluids in eng. oil. trans oil. front & rear axles and T-case' so change the fluids all at once, or a few at a time.
And to the second question, the answer is yes. It's ESP, NOT EPS.
Old Sep 5, 2021 | 08:31 AM
W164
Thank you
Old Sep 7, 2021 | 06:42 AM
Talal Al Hadidi's Avatar
ML350 bluetec 2010. W164
May I ask what is the T- case pls. ??
thanks
Old Sep 7, 2021 | 08:12 AM
chassis's Avatar
2017 GLE350 4MATIC
T/case is the transfer case. The device that splits engine torque to the front and the the rear axles.
I changed my t/case fluid and both axles at 60k miles. 2017 W166 GLE 350 4MATIC.
Old Sep 7, 2021 | 03:35 PM
Thanks for your kind reply
