Fuel return valve
Old Sep 9, 2021 | 09:17 PM
Talal Al Hadidi's Avatar
ML350 bluetec 2010. W164
Fuel return valve
My Mercedes is ML350 Bluetec 2010
vin 4JGBB2FB6AA593877
I need to know is there a fuel control valve just before the fuel tank
I saw a video for a car in which this valve stuck open which make several tries to start the vehicle
so , if the ml has the same valve I need to know it's location and part no. pls
thanks
Old Sep 10, 2021 | 08:45 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
Did you scan for codes?
And it would helpful to post the video you are referring to.
Old Sep 10, 2021 | 09:54 AM
Good day to Sir
I have code P0087 for the past year till now
the car works good , when cold start at first try , when engine hot it takes about 5 second to start and some time at second try
I did change new injectors
new fuel filter
new tank fuel pump
the video in the link below
Thanks a lot and have nice week end
Old Sep 10, 2021 | 10:02 AM
Talal, there are no "P" codes in CDI or Blue. If you do not get the proper scanner, I cannot help you.
Amazon Amazon
