ML320CDI Rack and pinion Boot Grease
Old Nov 18, 2021 | 06:30 AM
mercml320's Avatar
2007 ML320 CDI 4Matic
Hope someone can help me, I just found out my rack and pinion boot is ripped so I'm going to replace both of them.
does anyone know what type of grease I should use for the rack to stay lubricated.
Thank you in advance
Old Nov 19, 2021 | 04:38 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
You say rack and pinion boot but it does not contain grease, so it must be the axle shaft which does contain grease. Correct?
Old Nov 19, 2021 | 06:44 AM
mercml320's Avatar
I was talking about the joint and the rack pinion shaft, similar to this image. Hope this helps. I was just worried that since the boot got ripped and I didn't catch it on time maybe dirt and water got in and it will need to be cleaned some how.
Old Nov 19, 2021 | 08:02 AM
I am not interested in a photo you got over the internet. What I want to know is it leaking grease which are your words and again it doesn't have grease. It has P/S fluid running through the system. Explain this grease thing.
Understand that if you are leaking fluid, you must replace the entire rack and pinion. Read step #9 in the PDF.
File Type: pdf
Old Nov 19, 2021 | 08:27 AM
mercml320's Avatar
No it's not leaking anything, everything is running fine just the boot got ripped.
Old Nov 19, 2021 | 08:42 AM
Then why did you mention grease?
Here are the procedures to replace the boots. You will still have to remove the entire Rack and Pinion. Do not purchase after market boots, only M/B boots or else you will have to do it again. Go to dealer and give them your vin# for the correct part number.
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
Old Jan 4, 2022 | 10:28 AM
mercml320's Avatar
Thank you for your help this is perfect.
