Brake Disc Replacement
Old Dec 20, 2021 | 08:45 AM
anavabi's Avatar
2006 ML500, 2008 ML350
Hi Everyone
When should the discs be replaced. I have no braking issues except brake wear warning on my ML500.
Old Dec 23, 2021 | 02:00 PM
lkchris's Avatar
'10 CL550, '12 GL550
Normally the rotors (discs) are replaced at the same time as the pads. The warning, however, just indicates worn pads. There is no warning for rotors, just visual inspection. It's pretty easy, too, to visually inspect the pads. The friction material when new was pretty thick, about 1/2 inch or a little more.
With cool components, use fingers to check for lip at edge of rotor. This indicates how much metal has worn off the rotor. New rotors have no lip. The same lip will exist on the other side that you cannot access to feel. Any lip at all will probably indicate at least 1 mm wear. The wear limit is 2 mm ... remember the other side. There is no refinishing ... the material is gone.
New pads can be installed with old rotors. However, new rotors must be installed with new pads ... so best to do it all. Note: if warning light happens, it means you need new wear sensors, too. When replacing rotors, the caliper carriers are removed from the hub to gain access. New bolts are required when remounting the carriers ... bolts not reusable.
Old Dec 23, 2021 | 02:36 PM
anavabi's Avatar
Thanks for the advice. Would you say the caliper bushings need to be replaced too?
I've had this car since 2010 and never had to replace any brake part during this time while braking power was perfect all the time. I just changed the brake fluid last year. Ain't it amazing?
Old Dec 24, 2021 | 05:55 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
Originally Posted by anavabi
Hi Everyone
When the Brake Wear Warning appears it means you must replace the rotors/disks.
Old Dec 24, 2021 | 06:05 AM
Would you say the caliper bushings need to be replaced too? Only if they are damaged.
Whether they are damaged or not, lubricate the slide pins with lube.
Old Dec 24, 2021 | 08:09 AM
anavabi's Avatar
Thanks Major for your guidance.
Old Dec 24, 2021 | 09:48 AM
anavabi's Avatar
Just the last question Major, are the caliper bolts meant to be one time use and have to be replaced once they are undone? Thanks again.
Old Dec 24, 2021 | 01:15 PM
Read steps 6.1 & 6.2 PDF #1..
File Type: pdf
File Type: pdf
File Type: pdf
Old Dec 24, 2021 | 06:37 PM
anavabi's Avatar
Thank you Major
Old Apr 4, 2022 | 04:17 PM
anavabi's Avatar
Would you please let me have same information for the rear brakes. I'm planning to replace the rear rotors and pads.
Thanks Major.
Old Apr 4, 2022 | 04:50 PM
Thanks Major.
Here it is.
File Type: pdf
File Type: pdf
Old Apr 4, 2022 | 07:07 PM
anavabi's Avatar
Thanks Major
