Head unit turning off
Old Jan 8, 2022 | 11:59 PM
malbal's Avatar
mercedes benz ml350 2009
Hello everyone I’m having a problem with my head unit in my w164 it turns on and off every 30 seconds plays sound and I can use it normally for those 30 seconds but it then randomly turns off then turns back on anyone know what’s going on?
Old Jan 9, 2022 | 05:55 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
You must check for codes in Command/Sound with a scanner, not a code reader. Look at all the possibilities.
File Type: pdf
Old Jan 9, 2022 | 12:16 PM
malbal's Avatar
How do I scan the command unit for codes?!
Old Jan 10, 2022 | 02:50 AM
Do you own a scanner, not a code reader?
Old Jan 10, 2022 | 11:00 AM
malbal's Avatar
can you drop a link for a scanner? All I’m seeing is code readers also I’m just gonna try to replace the headunit do you think it will need to be re programmed?
Old Jan 11, 2022 | 03:12 AM
If you have a Bluetooth phone, order this one.
Don't think about replacing the radio until you read for codes.
Amazon Amazon
