ML350 Tramsmission
Old Mar 21, 2022 | 08:42 AM
Diana Matthews's Avatar
2015 Mercedes ML350
ML350 Tramsmission
Is it suggested to flush the transmission as the owners manual suggests? Is it safe or will it cause issues?
Old Mar 21, 2022 | 10:47 AM
S70Houston's Avatar
2018 GLC300 4Matic; 2008 ML550 4Matic; 2004 C320
It is definitely suggested and if done correctly will not cause any issues.
Old Mar 22, 2022 | 08:57 PM
lkchris's Avatar
'10 CL550, '12 GL550
No, just changing the fluid and filter is the correct procedure. Flushing is just something to flush your wallet.
Old Mar 22, 2022 | 09:06 PM
S70Houston's Avatar
You are correct, my bad. By flush I was as well referring to fluid and filter change. Apologies.
Old Mar 23, 2022 | 05:30 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
Diana, you are on the wrong forum and in the future you should post in the below forum.
https://mbworld.org/forums/m-class-w166-149/
