Fault Codes
Old May 1, 2022 | 09:40 AM
JohanSL's Avatar
2006 ML320Cdi Off Road Package; 2010 E500 Cab
Fault Codes
I had no problems at all then all of a sudden four different, seemingly totally unrelated problems at the same time???
  1. P0894 - Transmission slipping
  2. P2138 - Throttle position sensor
  3. P2270 - O2 Sensor Signal Stuck Lean bank 1
  4. The tailgate lock will not actuate and lock, (open and closing the tailgate works fine).
It does not make sense to me, is there anyway these could be interlinked by a control unit?
Old May 2, 2022 | 03:07 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
CDI & Blue vehicles do not have "P" codes in any module. You must check for codes with a scanner, not a code reader, which you have.
If you have a Bluetooth cell phone, this is the scanner you need.
Amazon Amazon
