Interesting new issue...erratic HVAC
Started a few weeks ago as it got hotter here in SoCal. The car stalled inexplicably in a car wash, and it's never done that. First symptom.
Every once in a while, after a cold start, will surge a couple times when maneuvering in the parking lot. Mild annoyance. Second symptom.
Third symptom, AC is freezing cold, but randomly decides where the air is coming from. Generally, I leave the AC in the blow in face configuration with maybe the floor vents opened as well.
What it does now is divert all air to windshield vents and driver/passenger window vents. No center flow at all. HVAC head unit airflow Lights disappear and it just does what it wants for a bit. Eventually it will change back to regular function, (sometimes after messing with the auto feature, sometimes after driving at increased speed) but will soon revert to the weirdness ad infinitum. No stored codes.
Vacuum leak? HVAC unit having a stroke? Electrical failure? Any ideas? I searched a bit and did not find any threads with this exact problem...most had either a concurrent temperature issue or appeared to be a passenger diverter problem. This is erratic and seemingly software or vacuum correctable. Has anyone else had this specific issue?
https://www.amazon.com/Autel-AP200-B...ps%2C78&sr=8-3
I checked all the vacuum lines and removed/dressed gaskets//replaced air cleaner assembly which helped with surging idle problem. What it appears to be is voltage related as it happens more at idle and after short trips. This makes me suspect a battery or alternator related issue. The secondary battery was recently replaced, but I believe the primary battery is the one the car was delivered with when originally purchased.
good luck.
I think I'll just replace the battery and see what happens.
