Active Curve system from 166
Yes, you can activate it in the computer, but I highly doubt the wiring harness and other hardware exists. If you want active curve, you're better off selling your current W164 and finding one with active curve. There is more to it than just the lamps.
I also highly doubt W166 parts will work. X164 and W251 parts might work.
actually I think it's possible, w164 and w166 have not so much difference, I need 2 stabilizers and ECU for it, only question in software which may be not supported by main ECU
You would also need a way to get steering position and shock position at minimum to the Active Curve control module. You might also need accelerometer data as well. I highly doubt that is possible without some major reverse engineering on the 164 and 166 control systems. You're much better off finding a 166 with Active Curve.
