2011 ML350 towing hitch fuse receptacle
Those 4 empty fuse slots are for the left side fuse blade. The slots for the other fuse blades are even there. Must be a separate fuse receptacle I have to install
https://mbworld.org/forums/gl-class-...n-problem.html
The first as mentioned is rear SAM damage.
The second is your car isn't programmed for trailer recognition.
The third is your trailer has LED lights and it doesn't like that. You will need an LED trailer light adapter.
The only connections to the fuse box for the trailer plug are the 12v trailer accessory power and trailer brake controller.
