ABS, ESP, DSR INOPERATIVE ( see owner Manual) drive to workshop)
I may have just drive 10 meters then this message would pop up. I can’t change the car to Reverse Mode.
if I continue driving, the car is not driving smoothly, I get a jerky drive
if I put car in Park(P) then try to shift to Drive(D) or Reverse(R) it’s not working.
But if I turn off the Engine/ignition then remove the battery terminals (+) first then (-) followed. The car would come back on and everything is working fine again. The car will go into Drive(D), Reverse(R) immediately the error message is gone.. but after some days the problem is back on
pls help- what might be the problem.(ML 350 2010)
The vehicle behaves like it is having a coronary when the problem hits.
Thanks for the update, I have actually changed the CAN socket, problem not solved. Car drives smoothly except for this issue. I’m at 117k miles. Anyone found a lasting solution to this issue? Please share with us. Thanks
He said 3 thing might trigger the error message on the dash.
1. A faulty ABS wheel cable
2. Low/Bad Battery or something is Draining the battery
3. Steering Angle Sensor
Replaced Auxiliary Battery for $50 cuz the message showed up on the dash. But since replaced no auxiliary message on dash
I have done step 1, and 2. Still getting the error message..
Will try step 3.
Will try step 3.
Unplug and plug battery be able to start the car again?
Looks like electrical is shorted to ground?
is it able to start the car then messages/errors popping up or you have to unplug/plug battery cable to start the car again?
Water leaking from rear door wires hardness down to 120v outlet caused shorted.
Water following down from cable to connector and outlet
Water inside
this problem caused same errors of duckdux’s post.
