p9015 no signal s20/1 window and mirror adjustment switch on switching bus
I can use the scanner to move the windows and door mirrors so theres 100% power to them.
Im assuming my only option is to go ahead and order both the drivers and passenger door switches? I just find it hard to believe they failed at almost the same time and it makes me wonder?
The passenger door initially wasnt working on the passenger window and mirror from the drivers controls. I could still select the drivers mirror and the button would light up with the red led..... but then the entire drivers switch seemed to drop out and not work at all when I continued to fiddle with it.... Then I realized the passenger switch didnt work either but not sure exactly when that went out pretty sure it was working tho.
The two rear window switches still work fine.
So lesson here is if you've got the time dont just give up on these benz modules if they wont take or communicate it the first time.
