ML550 /ML63 Wheel question
I am not sure on the off set of the ML63 wheel, but would imagine it sticks out a bit further with the wider tires compared to the stock 19inch wheel/tire set up.
Questions:
- Will the ML63 wheel fit on the ML550? I would imagine that it would.
- Does it work without the fender extensions?
- How does it look if there are no fender extensions as the ML63 has? (I still would want a classic look, so it has to look right)
Would anyone have a picture of the ML63 wheel and tire set up installed on an ML550 WITHOUT the fender extensions?
Thanks in advance.
Not to worried about the larger 20” inch wheel, more worried about the looks of it due to the wider tires and offset.
Do you have a pic of your setup?
Falken WildPeak A/T Trail 265/50/20 111V XL RBL
Zero issues with rubbing ever, no matter if airmatic is high or low.
If you could provide rim size and offset as well as tire size, that would be awesome.
Many thanks in advance.
Wheel size: J9.5 x 20, ET 46mm
Tire: 275/45 R20
I will use the ML63 wheel, which is period correct for the W164 ML:
