Replaced W164 front passenger door but not locking
Old Mar 17, 2023 | 12:45 AM
W164pain's Avatar
2007 Mercedes ML350 4-Matic
Currently own a 2007 ML350. Got hit on front passenger side and bought a 2008 front passenger door to replace it with. After installing, the lock/unlock button on door works for other 3 doors but does not lock itself also when I lock with my key the front passenger door still does not lock and I have to do it manually. Does it need to be programmed/ do I need to replace the lock actuator/ did I not install it right? Any insight?
Old Mar 17, 2023 | 04:07 AM
DLB_Adelaide's Avatar
GL320 X164 OM642 722.902
Subscribed. Curious to know this as well. I would have expected a like-for-like replacement of an actuator would just be plug n play.
Old Mar 18, 2023 | 03:27 AM
BlackML550's Avatar
2010 ML550 VIN WDC1641722A564750, 2010 B180
Each door has a module thats programmed to the car. If you still have the old door, your best bet is probably to swap the module from that one into the new one.
This video isn't in English but it shows you the procedure.
Old Mar 30, 2023 | 03:54 AM
BlackML550's Avatar
@W164pain Did you get this sorted?
Old Mar 30, 2023 | 10:16 AM
W164pain's Avatar
Not yet, I don’t have the old door unfortunately. Do you have any other recommendations? Do I need to get it programmed if that’s a thing?
