M272 Interchangeable engines and process.
On my diesel, I told the CGW that it had the higher output engine and it totally changed the performance of the car.
There's the option here to tell the car what engine is fitted.
Also, there's a similar option in the Engine ECU. My icarsoftMB2 sees two engine ECUs on my W221 S500... The 6 cylinder one and the V8 one. Obviously the car is a V8 but it suggests that the software is present for both and just needs activating.
Once it is installed, I may be able to assist with programming.
For the diff, I have only ever had V6 diesel 4matics and can confirm that the front diff and axle tube are indeed separate.
Do you have your 3.5 removed yet? I suspect that you will find that you are mistaken and that the front axle/diff is in fact a single unit totally separate from the engine pan. The ML front subframe is a beast and may be obscuring some of the detail.
Talking of the subframe have you confirmed if it is the same as the V8 one?
A.quick internet rummage suggests that you might need to replace your diff with one from the V8. Just be careful to ensure that the ratio is the same... If not then you'll also need the rear diff. At this point I would consider investigating if the axles are the same or if the 500 ones are thicker. You're already committed, may as well do it right😉
The transfer case is common to all and can simply be left attached to your gearbox. (With the running gear out, it would be a good time to replace the chain in the transfer case as a preventative measure.
Would suggest that the petrol front diff is a similar arrangement to the diesel ones... So should fit?
