Loose Shifter, Blinker Column
On my '06 model ML, when using either the shifter, blinker, or cruise control stalk, the entire plastic steering column assembly rotates like there is a screw or bolt loose somewhere. Looking underneath the column there is what looks like a deep screw hole, but I can't see in there well enough to see if a screw is present. Perhaps it fell out. Does anyone have any suggestions? The steering wheel itself is tight and fine.
Thanks,
Rob
Thanks,
Rob
Thanks,
Rob
Thanks,
Rob
Center the stalks and with an extended T27 male Torx socket, tighten the bolt, but don't over do it.
Only I think you mean T30, not 30mm.
![](https://cimg7.ibsrv.net/gimg/www.mbworld.org-vbulletin/739x790/steering_column_module_tighten_c7795aa5133d74e8ae821aaa31c3053c068351a0.jpg)
I have the same problem but only in summer! Really, when the car is standing in the sun for couple of hours, only in mid summer, like now, only do I have the same issue. Would it still be resolved by the same method as you described.
It's a T27 socket, not a T30.
