2009 ML550 Shudders at Low Speed/Idle
I ordered an Autel AP200 scanner, as I have one for my other car that seems to go pretty in-depth into codes and it should be here tomorrow. Anyone ever experience this or have any ideas on what this could be? I should not that this was a cooler rainy day... I am not sure if I have had a day like that since owning it and not sure if that is relevant or not, but wanted to add that.
Only maintenance I have done on it so far is replacing the oil cooler and gasket (was leaking into coolant), changing to G48 from G05 coolant, air filter replacement, and bleeding the brakes.
Cleared the codes and only rear lift gate code remained.
These are the stored engine codes, no transmission codes.
I still have a very slight shudder at very low speed (usually on a small hill) but I took to shop and they said 8/10 550's all have that same problem, and its cylinder #3 compression issue that Mercedes has known about with lots of their cars even 2018 cars they said still have the issue, and they said most likely will never cause issue and just to leave it alone or do expensive valve job..... Stunning Mercedes never recalled these engines to fix all of this, but I guess they did on later models recently.
They did say they had some luck lowering the idle on some of them and the problem was almost 100% gone and you have to really be looking for it to notice, so that will be next for me.
Was yours ever bad enough to the point where the car would not drive (before you did the MAF, air box fixes)?
Here is the description so you can look up, lots of guys had this problem and you can order it on AZautohaus or others have it too
AAZ Preferred Intake Manifold Adjusting Unit; Adjuster Repair Kit and Intake Gaskets; KIT | 273ADJKIT
On a side note, once I cleared all the codes the issue went away... instantly... and has not returned.
