Suspension Noise - Pictures included!
Old Oct 20, 2023 | 03:22 PM
helme009's Avatar
2011 ML350 Bluetec
Hi folks, new w164 Bluetec owner for a few months now. It has 175,000 KM (108,000 miles). Been hearing a suspension noise that sounds like metal on metal. It would sometimes go away. Its back now and worse. Had a look today and thought I would share pictures. The coil springs do not look the same on the front side. I have attached pics below for your reference. Can anyone tell me what is wrong and how it became that way?
Thanks in advance folks!
Front passenger side.
Front driver side.
Old Oct 20, 2023 | 05:57 PM
TripleDown's Avatar
2014 S63 2010 ML350 Bluetec 2009 SL550
Your spring is broken. Seems to be a common issue around here.
Old Oct 20, 2023 | 06:21 PM
helme009's Avatar
2011 ML350 Bluetec
I wonder how urgent this repair is? Seems like the broken part is away from the tire and other components. Wondering if anyone can chime in. Thanks
Old Oct 21, 2023 | 12:52 PM
S70Houston's Avatar
2018 GLC300 4Matic; 2008 ML550 4Matic; 2004 C320
You are asking how urgent it is to fix a major suspension component? Not at all if you are not driving!
Get it taken care of ASAP!!!!!!
Old Oct 21, 2023 | 02:23 PM
TripleDown's Avatar
Seconded ...you should not drive a car with a broken spring.
Old Oct 23, 2023 | 05:12 PM
helme009's Avatar
2011 ML350 Bluetec
I'm wondering what folks think about FCS strut assembly. Had a local indy quote me $1,000 (CAD) ($730USD) for front right and left. I've heard FCS are not the greatest quality. Arnott are another option but will have to order from Rockauto or locally. Should I bite the bullet and go with the chinese FCS? What are your experiences and do you have any brand suggestions?
Thanks,
Old Oct 23, 2023 | 05:17 PM
TripleDown's Avatar
My indy will only install factory MB parts due to many bad experiences with knock offs. If you too are saving money by using an indy tech, then spend the money on the real parts.
My $.02
Old Oct 23, 2023 | 06:32 PM
S70Houston's Avatar
My $.02
This time I shall second this one. 😊
Old Oct 24, 2023 | 02:59 PM
helme009's Avatar
2011 ML350 Bluetec
Hi folks, its me again. Back again for some advice. Seems like my indy is having a hard time sourcing parts. He said an assembly would be better and easier. The stealership gave me 2 qoutes. Spring replacement w/ strut (almost 3 grand CAD) and a spring replacement w/o strut for half that.
Wanted to know if its best to replace the spring only and leave the struts as is. If i was to go the indy route, I have a feeling alot of the strut assemblies I can order are of dubious quality. FCS seems to be the worst which is what is mostly available on rockauto and a the local part counters. There is another local parts counter that needs about 2 weeks to get an Arnott assembly.
Thanks in advance again!
Old Oct 24, 2023 | 03:23 PM
S70Houston's Avatar
IMHO, and with 108k miles, I would change BOTH, springs and struts on BOTH sides.
Does your car have the Airbag suspension? Does not look like it in the pics. If no airbags, get the BILSTEIN Strut Assembly. I put BILSTEIN's on mine and am happy.
Old Oct 24, 2023 | 03:25 PM
helme009's Avatar
2011 ML350 Bluetec
Yes, I don't have air suspension. Luckily.
Old Oct 24, 2023 | 03:28 PM
S70Houston's Avatar
Old Oct 27, 2023 | 12:19 PM
helme009's Avatar
2011 ML350 Bluetec
***UPDATE***
So been calling around for quotes. Folks on this forum rarely mention how much they spend, so I'll give a breakdown of each quote. All are in Canadian dollars. ALL ARE FOR BOTH FRONT LEFT AND RIGHT.
#1 - local indy
- FCS strut assembly (both sides) with labor = $1000
#2- Stealership
- Springs only = $1600
- Spring with new shocks = $2900
- they asked me to come in before they order the springs to determine the color as the W164 has 3 springs to choose from.
#3 - local indy
- Springs = $130 each
- shocks (BILSTEIN) = $600 each
- labour = 5 hours
- total = $2110
#4 - local indy - well reviewed and specializes in German imports. Will be my first time working with them.
- KYB front strut assembly = $265 each
- shipping = $125
- labour = 2.5 hours = $337.50
- alignment = $100
- total = $1255
i ended up going with #4. KYB has significantly better reviews than FCS. I dont think Bilsteins are worth the extra $800 on parts and labour. #4 was also the only one to include an alignment. Have to wait 2 weeks until the appointment. Will give another update when all is done.
Old Oct 27, 2023 | 12:47 PM
S70Houston's Avatar
I ended up going with #4. KYB has significantly better reviews than FCS. I dont think Bilsteins are worth the extra $800 on parts and labour.
Sounds good for right now. You will not find out for quite some time if the Bilsteins are worth the extra money. After a few thousand miles you will know.
The price quoted seems rather high, as I paid US $325.06 for one Bilstein Front Shock 24-166652 at my Indy with his mark up. I find this shock online at FCP Euro for US $239.00: Mercedes Shock Absorber – Front 1643200130 – Bilstein Touring 24166652 Bilstein 24-166652 (eeuroparts.com)
One comment found on the internet regarding the comparison KYB vs Bilstein: "Which is better KYB or Bilstein? The KYB's fade out too fast when traveling on Forest roads.The Billsteins will keep better ride quality for longer".
Old Oct 27, 2023 | 12:55 PM
helme009's Avatar
2011 ML350 Bluetec
Smile
Luckily I dont travel on forest roads. This thing is an luxury grocery hauler really lol. I think that indy shop was overcharging for the Bilsteins. Getting those is still not worth it as who knows what the car has in store for me next. I'm a realist and assume the worst.
Old Oct 27, 2023 | 01:12 PM
S70Houston's Avatar
Good luck.
Old Nov 28, 2023 | 05:01 PM
helme009's Avatar
2011 ML350 Bluetec
UPDATE
Thought I would give folks a quick update. Its been 2 weeks since I had the KYB strut assembly installed. I'm very impressed so far. Car rides nicely and steering become more nimble.
I recommend KYB for the W164.
Old Nov 28, 2023 | 06:13 PM
Joshinator99's Avatar
ML 63 AMG
KYB is a very solid brand, you should be in good shape. And a heck of a lot better shape than you were with that broken spring…wowzers! 😳
Old Dec 26, 2023 | 12:59 PM
DeanMassy's Avatar
lexus
