Flashing Yellow Triangle supposedly after Wheel Change ML320 W164
New to the forum. Just bought a 2008 W164 ML320 AMG.
I believe the car originally had 19" wheels which have now been replaced with 20" wheels.
New tyre sizes are Fronts: 265/45/20 and rear 275/40/20.
I get the flashing yellow triangle indicating a traction fault but definitely not a genuine traction issue i.e no wheel slippage or spinning. My first thought was wheel speed sensor going bad. However, the seller is adamant that the fault is to do with the new wheels and was fine before - Interestingly if you drive for a few miles sub 45mph and then accelerate up to normal speeds, the fault never reappears after that until you turn the car off and on again, which suggests some sort of automatic calibration happens and not the wheel speed sensor at fault. Obviously this is not practical longer term.
Has anyone ever experienced this or know the fix? - Image attached incase it helps!
Also, you'll be stressing the driveline and transfer case with this setup even if its not noticeable. I assume that you had the tyres fitted by a shop? Didn't they warn you of this, because they should have.
