ABS acting up?
Old May 19, 2024 | 02:21 PM
Smiffy177's Avatar
Ml 320 cdi
ABS acting up?
[img]data:image/svg+xml;utf8,<svg xmlns='http://www.w3.org/2000/svg' viewBox='0 0 50 50'><circle class='avatar-circle-default' fill='%2356ded3' cx='25px' cy='25px' r='20px'></circle><text class='avatar-text-default' x='49%' y='53%' fill='white' text-anchor='middle' alignment-baseline='middle'>S</text></svg>[/img]
Smiffy177 , Today 11:47 AM
My ML w164 has developed a fault with the following codes, 5132, 5136, 7270. This happened quite suddenly and it appeared as though the ABS was activating on 1 rear wheel. I disconnected the rear Sam unit o/s/R which allowed me to drive home. The Sam u it has been apparently b4 but it all looks good inside no water staining or corrosion on the plugs. Just a wheel sensor????
