#*%? …. REAR SAM UNIT…. 08 ML350
Dreaded dead REAR SAM UNIT FAILURE !! Help me out here please. I can see the corrosion at the plugs and some of the functions not working are the gas gauge , SRS system , turn signals , remote key , alarm. What should I do ?? Would like to get back up and running asap. Thanks
and see where the water is coming from- the w164 is notorious for water instrusion. My guess is its your tail light seals that will probably need to be replaced. Buy genuine MB seals. There are a few YT videos on how to replace. Place the seals on the frame- NOT around the tail light
also see here:
https://mbworld.org/forums/m-class-w...e-my-w164.html
Joshinator99 (07-23-2024)
rear sam
before replacing try cleaning . clean all the corrosion and if that works spray the board with a coating . All the info is available with a few keystrokes of searching .. youtube and this forum. good luck
