Big Whining Sound
Old Jan 28, 2025 | 03:35 PM
OUZO Power's Avatar
JGC SRT, ML 550, GLB 250
Big Whining Sound
Hey team. It's cold up here in Toronto. So maybe that has to do with it. But Over the last two weeks the ML has a large pitch whining sound from the engine bay.
It's not the power steering pump cause when at a stop I turn the wheel everything is ok. But under acceleration and even deceleration the whining sound is evident.
The lights everywhere look fine and don't dim at all. Is it possibly the bearing in the alternator about to fail?
Thanks in advance for your help.
Old Jan 28, 2025 | 07:31 PM
Joshinator99's Avatar
ML 63 AMG
Originally Posted by OUZO Power;[url=tel:9104328
9104328[/url]]Hey team. It's cold up here in Toronto. So maybe that has to do with it. But Over the last two weeks the ML has a large pitch whining sound from the engine bay.
Water pump?
Old Jan 29, 2025 | 12:13 PM
OUZO Power's Avatar
Originally Posted by Joshinator99
Water pump?
Ah yes. There is that possibility too. Thank you. Guess I just keep monitoring things till it gets worse to have a better idea what is the casue.
Old Jan 29, 2025 | 09:27 PM
ML 63 AMG
Originally Posted by OUZO Power;[url=tel:9104743
9104743[/url]]Ah yes. There is that possibility too. Thank you. Guess I just keep monitoring things till it gets worse to have a better idea what is the casue.
Yeah it sounds like the noise is rpm-dependent based on your description, so that was the only other thing I could think of off the top of my head.
Old Jan 30, 2025 | 02:32 PM
rapidoxidation's Avatar
2013 ML350 Bluetec
Anything the serpentine belt touches is suspect. Take the belt off and start spinning everything the belt is routed over and around; you'll find your answer in the one that isn't silent.
Old Jan 30, 2025 | 02:34 PM
OUZO Power's Avatar
makes complete sense. Thanks.
Old Jan 31, 2025 | 03:20 AM
BlackML550's Avatar
2010 ML550 VIN WDC1641722A564750, 2010 B180
You haven't said what engine you have. I'm assuming its the gas V6 ot V8.
In addition to the other suggestions, check for blow-by at the oil filler cap. If it seems excessive, then you might have a clogged up PCV rebreather valve. They have a centrifugal rotor that spins and separates the motor oil from the exhaust fumes. They block up and cause an almighty whining sound. It's located on the back of the head on the RHS (from driver view) and is encases in a black plastic fan shaped cover. These are a maintenance item.
Old Jan 31, 2025 | 08:29 AM
BlackML550's Avatar
Further to my previous post, increase the rpm to the level that creates to noise and then loosen the oil filler cap just enough to release any pressure and so it doesn’t cover you in oil. If the noise stops, its most likely the pcv valve as described earlier.
Old Jan 31, 2025 | 12:47 PM
imtheking's Avatar
Former R230, W220 and W221 owner
and for reference, here is the video intsructions. I did it over the summer myself.
USE GENUINE PARTS. DO NOT BUY THIS OFF AMAZON ETC...
Old Jan 31, 2025 | 01:35 PM
OUZO Power's Avatar
Thanks. It's the M273 5.5L. OK had no idea about the PCV. Will look into that also.
Old Jan 31, 2025 | 01:48 PM
OUZO Power's Avatar
https://www.youtube.com/watch?v=G4fv0i_OhOg
Thanks man. That's awesome.
Old Feb 3, 2025 | 12:07 PM
OUZO Power's Avatar
So a quick update on this. I was wrong. I assumed cause there was no whining when I turned the wheel it had nothing to do with the power steering.
So guess what. The fluid was low. Discovered a leak from the reservoir. I've replaced it before a few years ago. Topped it off and whining sound went away. Now I have to wait again for the weather to warm up and replace it once more. What is PITA is mines the V8. Little to no room to swap it out.
