ML500 2007 HELP PLZ
Old Feb 3, 2025 | 12:10 AM
Solidsnake888's Avatar
ml500
ML500 2007 HELP PLZ
so I was having code 0600 ECM when i pluged my code reader in but i was also getting random codes like charge battery but i just bought a new battery trying to daignose the problem then i got the error code again battery so i thought replace the alternator and would be all good so i replaced the alternator and as soon as i finnished installing the alternator i put the postive connection back on the battery because i was told just disconnect the postive while installing the alternator now my vehicle will not start please if anyone knows anything i would appreciate advice
ve
Old Feb 3, 2025 | 01:56 AM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
moved to W164 forum...
Old Feb 6, 2025 | 12:11 AM
vesiadog's Avatar
1998 SL500,2011 GL550,2009 ML350,past 1995 E320 Cabrio ,2005 ML500,2006 ML500,1996 SL500,1972 280SEL
battery voltage
What is the current battery voltage? Did you charge it?
Old Feb 14, 2025 | 08:18 PM
ml500
Help
12.4 i have a bran new battery and I just replaced the auxiliary battery bran new thinking that would help, I am stuck here my next guess is change the transmission fluid I'm in the cold-18c so the car won't shift gears till at least 80degrees seems to be I'm just unsure what to do
