2010 ML350 W164 4Matic - how to reset dash clock?
Old Apr 5, 2025 | 11:23 AM
Boxerdad's Avatar
2010 ML350 4Matic 2024 Hyundai Santa Cruz XRT with lots of mods...
I recently replaced the Command in-dash radio with a Kenwood DNX997XR unit. It fits great in the dash. Replaced all speakers, added 6 channel power amp, installed dual sealed sub woofer, interfaced wheel volume controls and backup camera. Everything looks and sounds great. There is one thing that I notice though and that is that the dash clock is way out of time. Did the factory dash clock interface to the original Command unit to receive "time of day" clock data? Is it possible to manually reset the clock or have I lost the dash clock function for good? Thanks in advance!
Old Apr 6, 2025 | 05:52 AM
BlackML550's Avatar
2010 ML550 VIN WDC1641722A564750, 2010 B180
With all the aftermarket head units I've seen, you usually can't change the clock in the dash. The only way to do it is disconnect the battery and when the real time matches the clock time, reconnect it and you're set to go.
Which head unit did you put in and are you happy with it?
Old Apr 6, 2025 | 06:30 PM
TripleDown's Avatar
2014 S63 2010 ML350 Bluetec 2009 SL550
Yes the factory Harman head unit was able to somehow set the analog dash clock. Not sure an aftermarket unit will be able to do that.
Old Apr 6, 2025 | 11:10 PM
EWT's Avatar
EWT
11 ML550, 95 Supra TT, 14 Audi S4
You need Xentry to change a setting to allow the time be be changed via the dash display. It shows up as an option in the settings menu once enabled. BenzNinja programmed mine. The other way to do it is to disconnect the battery at noon or midnight, and the clock will reset to 12:00 once the battery is reconnected.
