reversing camera upgrade
Old Nov 4, 2025 | 08:21 AM
stripey's Avatar
ML 350, W164, 2015
Hiya
I have a 2010 W164 ML 350. It's fitted with the standard, fixed line, reversing camera. I have found a camera that says it's a dynamic one for the W164. Anyone any experience with that kind of retrofit?
Old Nov 9, 2025 | 03:15 AM
BlackML550's Avatar
2010 ML550 VIN WDC1641722A564750, 2010 B180
How dis this go? Did You keep the Standard headunit? What had to be changed i.e. wiring?
Old Nov 11, 2025 | 03:36 AM
stripey's Avatar
ML 350, W164, 2015
AT this moment, I'm waiting for the camera to arrive.
I am cynical as to whether it will work as it only appears to have the "normal" connections and I would have expected an additional feed to read the steering angle. However, the manufacturer is adamant that it works and I can get a refund if needs be so I thought it was worth a try - especially as it appears to be a straight swap for the original.
You asked about head unit - I have already swapped that for a Kenwood unit.
I'll keep you posted
Old Nov 11, 2025 | 05:36 PM
AL5461's Avatar
W221 S500
The dynamic parking guidance takes its inputs from the Chassis CANBUS via the Central Gateway. The cameras are the same regardless of the system on the car... Basically power, ground, Video and shielding. Only two connections from either ECU to the Head Unit: Video and Shield.
The seller is correct. Expect no magic from the camera.
Old Nov 12, 2025 | 06:27 AM
stripey's Avatar
ML 350, W164, 2015
