ML diesel MPG?
Same here. I really wanted to go with a diesel but it's tough when diesel is 80 cents more per gal than premium here. When gas prices are higher, the spread is sometimes only 20/30 cents. I do think the diesel will hold it's resale value better down the road.
For gasser midsize SUVs, the ML350 would be near top of list. Another (odd) top contender IMO is the VW Touareg Hybrid. Not because of the "hybrid", but in spite of the hybrid component. That Audi-based supercharged V6 is a great motor. It's listed at 330 HP but folks are reporting that it dynos at more like 360 HP. I wish it was offered as a stand alone engine option in Touareg and Audi Q5.
And it gets good gas mileage.
The real world FE of the Diesel is better than that.
I would find out the driving range for a tank of gas vs diesel.
For example my ML can consistently get 600 Mile per tank (+900KM).
I wonder what is the range for a gas ML?
The huge torque is what attracts me to the ML BlueTec.
It is interesting to note that here in Canada 80% ML are Diesel!
If you typically drive highways and do a higher mileage than the normal driver then the Diesel is the better vehicle.
My fuel costs used to be +$900.00 per month.
Now that I have switched all my vehicles to Diesel it's almost half of that!
If you cover less than 15,000 miles per year then the gas version would be the better choice.
For me, after experiencing the benefits of a Diesel vehicle I will never buy another gas vehicle.
1. Per your data (attached) the diesel uses 107 gallons less fuel per
year, but the barrels used is virtually identical? Please explain. I thought diesel was easier to refine.
2. The CO2 output between the two is also almost identical, despite
the lesser fuel usage of the diesel and I thought lower CO2 content of diesel.
I got this resopnse this morning (impresseive turnaround):
"Thank you for contacting us. The EPA has a webpage that discusses the calculation of CO2 from a gallon of gasoline and a gallon of diesel. A gallon of diesel produces more CO2 than a gallon of gasoline so, even though the diesel ML350 uses fewer gallons, the difference in CO2 output isn't as great as you may expect. The link and relevant content is pasted below:
http://www.epa.gov/otaq/climate/420f...tm#calculating
Calculating CO2 emissions
The Intergovernmental Panel on Climate Change (IPCC) guidelines for calculating emissions inventories require that an oxidation factor be applied to the carbon content to account for a small portion of the fuel that is not oxidized into CO2. For all oil and oil products, the oxidation factor used is 0.99 (99 percent of the carbon in the fuel is eventually oxidized, while 1 percent remains un-oxidized.)[1.]
Finally, to calculate the CO2 emissions from a gallon of fuel, the carbon emissions are multiplied by the ratio of the molecular weight of CO2 (m.w. 44) to the molecular weight of carbon (m.w.12): 44/12.
CO2 emissions from a gallon of gasoline = 2,421 grams x 0.99 x (44/12) = 8,788 grams = 8.8 kg/gallon = 19.4 pounds/gallon
CO2 emissions from a gallon of diesel = 2,778 grams x 0.99 x (44/12) = 10,084 grams = 10.1 kg/gallon = 22.2 pounds/gallon
Note: These calculations and the supporting data have associated variation and uncertainty. EPA may use other values in certain circumstances, and in some cases it may be appropriate to use a range of values.
Additionally, our website's emissions values are calculated based on Argonne National Laboratory's GREET Model (http://greet.es.anl.gov/) which includes upstream emissions including extraction, processing and fuel distribution. The EPA publishes tailpipe only emissions which is quite different. The processes associated with refining diesel fuel have increased in recent years as the U.S. has transitioned from diesel with a sulfur content of 500 parts per million to the new Ultra Low Sulfur Diesel with a sulfur content of just 15 parts per million. This new Ultra Low Sulfur Diesel became mandatory at the end of 2010. It's been our observation from user feedback that the EPA test cycles tend to undervalue diesels particularly if you are doing a lot of highway driving. Many diesel owners report exceeding the EPA ratings so the diesel may well be better than the numbers show.
If you are interested, the EPA also has a website called the Green Vehicle Guide which shows pollution and emission scores based on tailpipe emission:
http://www.epa.gov/greenvehicles/Index.do
I hope that some of this information may be helpful.
Sincerely,
www.fueleconomy.gov
There goes all of the diesel mileage advantage, ........
I have a brand new ML350 (Gas), and I average about 23.0 – 23.5 with every tank. I have only filled up 2.5 this month, which is good for me(with my last car I filled up every week @ 19 gallons...Dodge Charger Daytona at $70x4 = $280 for gas)
Note: The half tank was a trip for Thanksgiving
Now with my ML350 I have filled up twice and each cost about $82, so I should be saving about $120 a month. With both tanks getting me 1st (520 miles) and my 2nd (550 miles)
I don't drive much highway, a lot of going through country and stop and go in my work area (city)
Please base the MPGs on a variable, not a set in stone this is what you will get because this is what he is getting.
For me we live in the city area and not every gas station has Diesel, I want my girl to drive the ML sometimes so I didn't want her to run out of gas looking for a station that may or not have Diesel. Gas did it for me, and it does very good for me.
I thought I would want the TQ, which I really did, until I went up a 12 ft dirt/grass hill at a pretty good incline and this gas V6 engine did it very well. I am sure the diesel probably does a better job, and what it seems like is that the diesel does better on real-world highway...if it is a straight (no hills, dips and such) road/highway/street I can get as high as 27-28 mpg...going at a steady speed. However if not, it’s at about 22...which really annoys me because there are not many 0 degree roads in the DC metro area.
It's funny because if a random person was to read this thread, they would be like "Why are these rich folk complaining about the cost of gas"...which I think we are not...its just conversation as to some really want to see if the diesels would be worth the $1500 am I correct?
If gas was a very big concern I doubt we would be driving 50k - 60k SUVs...our asses would be driving Volts, or a Prius (not a leaf, those things are ugly as hell)
Remember, during the reviews I have noticed that the reviewers do point out the gas engine is smoother and idles smoother & less noisy than the diesel...they do say in the same sentences that the diesel, however idles very good compared to the competition.
So even though the combined rating on the ML350 is 19, I have not gotten below 23 myself.
And if you want to talk about money, please include the cost of the Adhoc that needs to be done every 2K? or is it 3K…
I really wish our cars had that TQ, my RPMs go to about 2000-2200 when going up hills.
Oh well, I got my ML350 with Package 1, wood trim and a couple other options on Holloween for 46K. They was not giving much money off the diesels
Driving it compared to the R was revealing. A lot less road noise on the ML with regular tires compared to the run flats on the R (I'll be happy to be rid of those buggers!). A lot more refined and the extra power was obvious. The 7speed on the ML was infinitely smoother than the R and the "pregnant pauses" that were apparent when accelerating from a stop in the R are absent in the new ML.
Sign the papers tomorrow and take delivery on Thursday night.
Per the fuel economy.gov website, much to my surprise there is no clear advantage for the diesel, despite its higher mileage. They admit the mileage rating per the EPA may be conservative, but still not compelling. Resale value does seem to be in the diesel's favor, but maintenance is higher (AdBlue onlue needs to be replaced about every 10k, though). Then there's the quality inconsistency of diesel fuel sources to consider.
It's good to hear you're getting 23+ with the new gas model; I've never seen that high with my '06, even on the highway (I tend to drive a little fast, though). While I have a BlueTEC on order, I'm starting to lean toward the BlueEFFICIENCY.
10k for adblue? I read in a article you go through 1 gallon of the stuff every 2,200 miles. So that the ML350D holds 4.x gallons of it?
This is what I found from an review:
Fuel economy is a diesel advantage. EPA fuel economy numbers are 20 city, 25 highway, 3 MPG better than the gasoline engine. These saving are easily eaten away by the price of AdBlue and diesel fuel that seems to average 20 cents more per gallon than premium gasoline in Seattle. Trust me though, you’ll love the torque.
Full Review - http://drivencarreviews.com/2011/09/...-video-review/
My opinion is, don't get the D if you are attempting to try and save money...get the D, if having a huge amount of torque is what you need. I bought my ML350 to get around in the dirt,snow and haul my future family around. Regardless, its only 1,500 more, your already spending at least 50k, looking at the D as a money saving option shouldn't really be the case. It should be hey, I need the diesel because I like the feel of the engine, the torque at low RPM, or you may want some extra TQ when pulling a trailer. I would expect the diesels to get better MPG when pulling a trailer, or going up a dirt hill.
Oh yea, to get 700 miles on one fill up means you would have to average about 29 MPG for the entire tank. If thats possible, D members chim in...the coolness factor is something to be very happy about.
I am not trying to differ your options, not my intention...I came here looking for information before I bought mine. So I am hoping others find the information useful. However, make your own decisions and really come to a conclusion on what you need. Truthfully, you really can't go wrong on any option of the ML350, just a drop dead sexy SUV, and a REAL SUV, not no lifted station wagon, like the new Explorers, and almost every Toyota, and Honda.
For me and most people who live in USA, it is not that way.
Check here...http://fuelgaugereport.aaa.com/?redi....com/index.asp
I live in VA, and Diesel is about 30 cents more. So to fill up my tank it would cost a little more than $7 bucks. I fill up about 2 twice a month so it would only cost me $14 more each month to have a Diesel. Not bad really, $14 bucks is nothing even on the year its only about $170 bucks.
This month it looks like I have filled up 3.5 times this month, so having a D would cost me an extra $26 dollars this month. I understand that diesels get more MPG so I would be able to go longer, however after thinking about it. Even though if I had the D, I may not have to fill up today, though I would have to fill up tomorrow same with each other fill up, thus making me still fill 3.5 times this month.
StateRegularMidPremiumDiesel
Virginia
$3.196
$3.372
$3.500 (93)
$3.825 (diesel)
Availability and cost of fuel, now that's a different story. USA oil companies seem to have made the decision moons ago to not expand diesel. Its less expensive to refine than gasoline and it produces 1.15 times more energy per volume than gasoline. It should be cheaper, but supply and demand rule the day. Today, in the midwest, its particularly scarce because of (temporary?) high-use of diesel in ND.
I hope this helps. Having driven and owned both, for me there's no question. I'm looking at a ML350 BlueTec.
I understand in the diesel cars, the mpg is very much a great increase over the gas version. So, in that case it would be very understanding to go with a diesel for fuel cost savings.
Thats only the point I was trying to make in my above statments. The D vs. G fuel savings in our MLs is really not a very obvious reason to buy the car. I stated previously, if you need the TQ best option is the diesel.
I even search high and low in MB specs and information to see if they state the cost saving benefits of the two. However, they only state you can go up to 600 miles with a diesel. Never anything about how much money or could be saved. When I first went on the market for an ML350 my intention was to get a diesel, however after going and search which gas stations offered diesel...I really didn't want my girlfriend or I searching for not just a gas station, but a diesel gas station.
I am actually looking forward to next year, rumors are floating around stating that the ML350 will have a hybrid next year that will be part diesel and hybrid technology. That should be very cool...
With diesel or gasser engine, that would be cool.
Current VW Touareg hybrid can only go about 3 miles on battery but does have an awesome (IMO) gasser motor, 3 liter supercharged V6 with 330 HP/ 380 HP when coupled with electric motor. That's a tempting rig that I don't believe has caught on--maybe becuase of the $61K price.
But ML can be WELL above 61K with options.
In MN where diesel is plus 80 cents above premium
"U.S. exports of gasoline, diesel and other oil-based fuels are soaring, putting the nation on track to be a net exporter of petroleum products in 2011 for the first time in 62 years. A combination of booming demand from emerging markets and faltering domestic activity means the U.S. is exporting more fuel than it imports, upending the historical norm . . ."
All of which is keeping prices high.
We are still the largest net importer of crude oil, though, so energy independence won't come anytime soon.
If the next ML hybrid is 25-30 pure battery...that will be the day I trade in.
I would be able to get to work on battery, and I could talk to my job about providing me a plug to charge (it will influence others)...and I could get home without ever using a drop of gas.
I could have the SUV I always wanted, yet save money...thats a win-win.
Thats for providing this information, I didn't know it would be a plug in. Thats really cool, and if it is a plug-in I would be able to get a tax write off (7500) right?
45K Toyota Highlanders...
45K Honda Pilots...
WHAT THE HELL IS THE WORLD COMING TOO!!!!
Keep in mind that all the info is speculation and mother Mercedes could pull the plug on any of these if they desire.
The internal combustion engine mated to the electrics seems to have several speculated possibilities, like a small 4 cylinder diesel, 3.5 liter gasser, and even a 3.5 L twin turbo gasser in one article.
Time will tell.
