Rim Offset for W166
Old Nov 7, 2011 | 05:30 PM
DC-IT's Avatar
2013 E350 BlueTec, 2011 VW Jetta TDI
Rim Offset for W166
Does anyone know what is the specs for the W166 rims?
My 2011 ML has the following:
Bolt Pattern: 5x112mm
Off set: +45mm
I've just fitted Winter tires and rims and would like to know if my Winter tires and rims would fit the W166 if I decided to upgrade when my lease is up.
Old Nov 7, 2011 | 10:43 PM
GregW / Oregon's Avatar
2020 GLE 450; 2023 BMW M2 Coupe
Winter wheel offset
Off set: +45mm
Check pages 377-78 or the owner's manual. Approved winter tire wheel offsets run from 56-59mm. Bolt pattern should be the same, but not sure on hub diameter.
http://www.mbusa.com/vcm/MB/DigitalA...12-M-Class.pdf
Old Nov 8, 2011 | 05:55 PM
DC-IT's Avatar
Thanks Greg.
Guess my rims won't work on the W166!
Old Nov 8, 2011 | 07:40 PM
Thanks Greg.
You could use 12mm hubcentric spacers.
Edit: Need to verify hub diameters are the same, but I doubt they changed. Would also require longer lug bolts.
Old Nov 9, 2011 | 08:25 AM
DC-IT's Avatar
Thanks for the suggestion Greg.
