2012 Euro version ML63 headlights
Old May 27, 2020 | 09:16 AM
Kevin9664's Avatar
2011 E550 Cab & 2015 ML400
Old post but I just bought a US 2015 ML400 and looking into changing my headlights from amber to white. Anything new on this front? Part number for direct swap? Anyone actually try to open up existing headlamps to change bulbs? Any new info would be helpful.
Old May 28, 2020 | 01:10 AM
black06c230's Avatar
mgLipGD
I haven’t but a buddy of mine has done custom lights on his. Said he would never do it again and he works at a very high end body shop. Problem said is you can’t just open the up. They have permaseal so it’s not a easy warm in the over and pop off the lenses.
I had plans for my GL but when he told me I was like PASS.
Old May 30, 2020 | 08:33 AM
corkshoppe's Avatar
Top Answer: 1
13's550/2000's430/13'gl63/'13's550/10's63
there are you tube videos of baking the lens of and changing the bulbs,
Old Jun 16, 2020 | 09:47 AM
Kevin9664's Avatar
Anyone know the part numbers for the euro headlights to replace my xenon headlights?
My Sticker Option Below. (2015 ML400)
319 Lighting Package: Bi-Xenon Headlamps with Active Curve
615 Bi-Xenon Headlamps w/Active Curve Illumination
608 Adaptive Highbeam Assist
Old Jun 19, 2020 | 07:32 AM
Paul Lambert's Avatar
2014 ML350
Just be aware that you can fail inspection if your change your turn signals white in your state depending on the wording of the inspection checklist, and may make you susceptible to being pulled over in some states if front turn signals aren't amber.
Old Jun 19, 2020 | 07:36 AM
Kevin9664's Avatar
The turn signals are still amber. It’s a separate light. It’s kind of like a Daytime Running Light except it it’s not on in the daytime. It also removes the amber corner reflector as well which makes it look a lot cleaner.
