Adaptive High Beam Assist inconsistent
I was had same concerns and worry, but I have discovered that it really is intellegent. It decides how far you need to see at that speed.So it is speed sensitive plus the darkness of the area.If you are slow in speed in a small country road you need to switch it to manual if you really want high beam. but if you are driving at 40mph or so it comes on in dark road as it knows you have to see far away , when you are slow it thinks you do not need to look far ahead.
Does this make sense?
Give it a try , but do not speed too much on a small road while testing your lights and cause a problem!
