External Hard Drive for ML350
Initially I thought an external hard drive was a good idea, but I ran into the following snags:
- Every time the car starts up the hard drive is re-initialized (scanned for music and pictures by the ML), which takes time.
- The last song that was playing is not remembered, the command system starts playing from the first song it finds.
- Mechanical hard drives stop working at high altitude (as anyone who went skiing with those old school iPods found out), even when it works the life span of the drive will be dramatically reduced.
So I ended up getting a 128GB SD card from Amazon for a little over $100, it works great - none of the problems I listed above!
I have around 9,000 songs loaded with more than 50% capacity remaining. The owners manual says that the maximum you can have on the SD card is 15,000 songs, so I suspect that I'll run into that limit long before I run out of space on the card.
2c
Give your device some time (say 30 minutes?) and see if the complete list shows up?
Oh, and some of the music is european, so I get omalauts (å, ü etc.) & ß on the digital display, complete with CD cover and title of my original CD.
