Cornering Lights
Old Jan 11, 2013 | 12:28 PM
dougiebear's Avatar
2013 ML BLUETEC JULY 31
Originally Posted by GregW / Oregon
That make sense as far as justification goes, but sucks from a practical standpoint. Seems like the W164 with one "fog" light that would come on when turning was far more confusing than the W166's solution integrated into the headlight cluster. Thank to DOT for saving us from good engineering again.
From some of the above pics it sure looks like a separate bulb who knows but it should be a doable fix. In Canada we got robbed of Mbrace too but price still went up
Old Jan 11, 2013 | 03:08 PM
FLICK12's Avatar
ML350
Originally Posted by Thimee
It feels like a step backward - my old 2007 S550 had both adaptive bixenon as well as cornering lights. I wonder if that slipped though regulations, or if MBUSA got a nasty letter from some officials somewhere?
At any rate, I wonder if adding cornering lights to USA ML's is a simple as adding a bulb? If all the wiring is intact it might just be... When the sun rises later today I plan to take a better look at the light cluster housing in mine to see if there is an easy way to get inside (not sure if these have a light bulb replacement access hatch in the wheel well since they're xenon and not regular bulbs).
Take a look at the S550 on the Web site and build a car with the lighting package. You will see it specifically states cornering lights as part of the package whereas the ml350 lighting package does not state it.
Posted from Mbworld.org App for Android
Old Jan 11, 2013 | 04:19 PM
xxGenericSNxx's Avatar
99 ML430, 01 CLK55, 07 R63, 15 E63 Wagon
Seems like it'd be plausible, although, it may also require some coding to get it to work. Because right now, the car doesn't give you an error code for the missing bulbs- so you probably have to tell the computer to activate the function so long as the socket and wiring is already there.
Old Jan 11, 2013 | 07:25 PM
dougiebear's Avatar
Originally Posted by dougiebear
OK folks if you piece all the info together it makes sense. In USA with the adaptive lights(AHA)(bixenon) it is illegal to have this style od cornering lights. Engineering calls them highspeed. The bixenon beam shines down and into the reflecter. Inside bottom which produces light to the side of the turning direction. USA law states that the beams on each side have to do the same thing on the road. Both up both down both right both left. Europe and Canada can have each side operate independently. In Canada because we are such a border country and cross to USA so much it was determined we won't get them.
Maybe enough of us can change their minds. But it is USA HTA rules that say no because of the bixenon/ctive issue. Our highbeam adaptive even is the same both side which all of MB videos show independent beams at different heights. Law has to catch up with technology. Hope this give some peace. They are capable but will not be able to be activated.
UPDATE
Seems from Ians comment about the bulb (my first idea) that the "tricked out" Adaptive lights do not function as cornering lights (as MB tech group said)
This would comply with USA and CANADIAN laws so lets unite and go after them gang.
Old Jan 11, 2013 | 10:38 PM
GregW / Oregon's Avatar
2020 GLE 450; 2023 BMW M2 Coupe
Cornering lights
OK folks if you piece all the info together it makes sense. In USA with the adaptive lights(AHA)(bixenon) it is illegal to have this style of cornering lights.
What is your reference. I have not found anything in FMVSS 108.
So why not just turn on both sides, even though only one side is needed?
Old Jan 13, 2013 | 12:59 PM
dgiturbo's Avatar
His 2019 RAM Cummins Turbo Diesel Laramie; Her's 2007 ML320 CDI P3; Mine BMW R1200R
Hey check this, my 2012 GLK has the Xenon's factory light package, with LED's where the fog lights should be, and cornering lights. I was trying to see how they did this, so I turned the wheel enough to trigger the system, and what I saw is a small bulb in the headlamp assembly that shines brightly into a reflector that then projects the light where needed in the corner. It times out after a few seconds.
Just offering this as an example to check with your ML's.
Old Jan 13, 2013 | 01:15 PM
  #32
Cornering lights
Can you tell if it's a bulb or an LED? If it's a bulb, there must be a way to access it.
Old Jan 13, 2013 | 06:45 PM
  #33
iankayem's Avatar
X350d GLE500e 2017, ML350 BlueTec 2012(sold), A200 2013, ML350CDI 2009(sold), Aston Martin DB7 2003
I notice in the owners manual there is no description for replacement of the cornering lamp globe. Must be because you have to remove the HID set up and no one but an MB service tech is allowed to touch that regardless of how many engineering degrees you have. Probably deleted under advice of lawyers.
Old Jan 13, 2013 | 11:25 PM
  #34
cookstar's Avatar
2005 ML350, 2008 GL320, 2013 Gl350
what If I have Phd degree from clown college?
Old Jan 14, 2013 | 01:38 PM
  #35
venchka's Avatar
2004 Volvo XC70; 2012 GLK 350 4matic
Cool
Originally Posted by venchka
OOPS! Apparently not.
Also linked to the turn signals. At, or below, 25 mph IF the turn signal is activated, the corresponding cornering light comes on regardless of steering angle input.
Funny. Our baby SUV (21012 GLK) has the cornering lamps. Clearly an extra pair of halogen bulbs mounted inboard of the primary HID Bi-Xenon lamps. Nice feature way back in the dark woods.
Wayne
Previously posted. I don't get no respect.
Greg, as I said last week, our 2012 GLK cornering lights are a seperate halogen bulb in a seperate reflector/housing located on the inboard side of the headlight assembly. Sadly missing from the 2013 GLK also. Friggin Nanny State strikes again.
Glad we have a 2012 with cornering lights.
Wayne
Old Jan 14, 2013 | 05:43 PM
  #36
iankayem's Avatar
Is that the Japanese Royal School?
Old Jan 14, 2013 | 09:38 PM
  #37
YYZ-E55's Avatar
MY17 E43 Matte Selenite/Macchiato Beige, MY16 GLE350d Tenorite/Crystal Grey, MY17 B250
615 = active bi-xenons
621 = active bi-xenons with ILS (intelligent lighting system), the functionality of which NAFTA regions are not privy to.
Old Jan 14, 2013 | 11:00 PM
  #38
Wayne
Begs the question of why 2012 MLs don't have those feature. Must be some change in the standards that they knew was coming.
Old Jan 15, 2013 | 06:32 AM
  #39
FLICK12's Avatar
ML350
Wayne
One again, check the specs on the S class when you build the car from the Mercedes website. It clearly states the cornering lights as a feature of the lighting package.
Old Jan 15, 2013 | 02:31 PM
  #40
venchka's Avatar
Features online do not guarantee features on the vehicle.
If you all remember, there was a serious delay while the HID headlight unit was redesigned. The loss of cornering lights may have been the background reason. Since our GLK was built in Germany, M-B may have been able to use the same units from 2010 & 2011 on the 2012 model. The headlights were redesigned for 2013 & the cornering lights were dropped.
Wayne
Old Jan 15, 2013 | 02:47 PM
  #41
GMW's Avatar
GMW
2013 ML63 AMG PP
When I checked on the 166 ML with cornering lights, that I took a picture of weeks ago, there were LEDs not bulbs used for the cornering light it self. The LEDs reflected against the reflector and a whiteish/blueish light was shown when in motion at night.
Old Mar 16, 2013 | 03:28 AM
  #42
GMW's Avatar
GMW
2013 ML63 AMG PP
A video of the corning 'spot' light in action from my ML
Old Feb 4, 2015 | 08:16 AM
  #43
acela11's Avatar
2012 c350 sedan
does anybody know how to change this bulb?
