Copy iTune Playlists to USB flash drive
Old Mar 4, 2013 | 04:29 PM
sxue888's Avatar
13-ML350 BT;06-IS300;99-4Runner
Anyone tried to copy the iTune playlists to an USB flash drive and play in COMAND? Will the iTune lossless files play as well?
I did copy a playlist from iTune to DVD exported as data and it plays.
But it's limited to 4G per DVD. But I have not found (google) anyone has successful copy the iTune playlists to an USB flash drive.
Old Mar 4, 2013 | 05:01 PM
jellies's Avatar
ML350
click and drag the playlist to a folder in the USB stick and iTunes will write all the mp3s there
Old Mar 6, 2013 | 03:32 AM
sxue888's Avatar
I just try and it didn't work:
1) Plug in USB drive
2) Open the drive in Window explore
3) Open iTune, playLists, drag a play list and drop it to the drive
Anyone tried this before?
Old Mar 6, 2013 | 05:23 AM
jellies's Avatar
ML350
Almost - I opened a playlist, selected all the tracks and dragged it into a folder - they all got copied.
The other way is to individually 'Show in Finder' on each one and then copy that file.
Old Mar 6, 2013 | 02:49 PM
frtdog's Avatar
2020 GLE 450
SXUE888 - Did the DVD you made play the music back with good quality. I knew you could save a playlist as data but I did not know our player would play it as music.
Old Mar 7, 2013 | 08:30 PM
frtdog's Avatar
2020 GLE 450
To answer my own question I put my iTunes on a DVD and by golly it works. Thanks for the heads up on that.
Old Mar 7, 2013 | 10:48 PM
sxue888's Avatar
Yes. the COMAND plays the DVD and displays the art works too with the exported playlist. But I can't get a playlist to an USB drive and do the same thing. I know you can copy the files but you loss the art works.
The sound quality is good or bad depends on your original music import and export setting. MP3 or ACC sucks when it compares with the DVD-Audio.
Old Mar 14, 2013 | 04:50 PM
NickTH's Avatar
2015 E400
I just found the file where all my Music is stored. It's in my "Music" Library.
Copied to a short snub USB like:
http://www.newegg.com/Product/Produc...FW2nPAodWyoAiA
I got the 32 Gb model. Holds all my music on it. & It barely takes up any space in the compartment...
Old Mar 14, 2013 | 04:58 PM
sxue888's Avatar
Thanks for the reply, questions for you
1) did you just copy and paste the itune music directory ?
2) when you play your USB , is the album art work display?
Thanks,
Old Mar 15, 2013 | 12:50 PM
NickTH's Avatar
2015 E400
Yep. Just copy & paste all the music files/folders as is.
MB does a great job of indexing the files & displays the cover album artwork on screen. Looks great.
Old Dec 20, 2013 | 05:58 PM
ESTrader's Avatar
2013 C 350 Coupe
I'm having trouble getting my 128G Sandisk USB flash drive to play my copied iTunes files in the car. It's weird it will only play songs I downloaded from iTunes. It won't play songs I ripped from legit CD's. Any ideas as to what might be the issue?
Old Dec 20, 2013 | 06:10 PM
Nanook's Avatar
'18 GLE63S AMG /'19 PORSCHE TURBO S / '09 CORVETTE ZR1 /'14 LEXUS RX350/'16 RAV4 Ltd
ANd no will not play lossless
Old Dec 20, 2013 | 06:30 PM
ESTrader's Avatar
2013 C 350 Coupe
So it won't play lossless from the USB but it will from my iPhone?
Old Dec 20, 2013 | 06:33 PM
Nanook's Avatar
I must say I'm not sure,,,what type of lossless..it won't play most that I've tried..flac, aiff...again..not sure
Old Dec 20, 2013 | 06:44 PM
ESTrader's Avatar
2013 C 350 Coupe
All of my CD's were ripped to Apple Lossless. These are the files that won't play from the USB stick, but they will play when I connect my iPhone.
Old Dec 20, 2013 | 06:48 PM
Nanook's Avatar
I'm not sure..not sure if having the phone connected hardwire vs bluetooth makes a difference either..
All I know is it won't play music I d/l from HD Tracks...which would be great if it did
Old Dec 20, 2013 | 06:50 PM
ESTrader's Avatar
2013 C 350 Coupe
Yeah it's a real disappointment. There's not much support for us audiophiles.
Old Dec 20, 2013 | 06:52 PM
Nanook's Avatar
Have you heard the B&O system by chance ?
Old Dec 20, 2013 | 06:53 PM
ESTrader's Avatar
2013 C 350 Coupe
In which vehicle?
Old Dec 20, 2013 | 06:55 PM
Nanook's Avatar
Any.. just wondering if it plays lossless and if it's worth the $6500ish
Old Dec 20, 2013 | 06:56 PM
Nanook's Avatar
Pretty funky looking tweeter on the door I'd say
Old Dec 20, 2013 | 06:57 PM
ESTrader's Avatar
2013 C 350 Coupe
I've only heard it in the Audi S5. It was much better than the system in my C350.
Old Dec 20, 2013 | 07:19 PM
fabbrisd1's Avatar
A gaggle of MB's
The B&O system is "primarily" amplication/delivery - there are a couple of added sound profile use adjustments avail on the COMAND - other than that the head/COMAND unit technically is identical.
The B&O - awesome imaging and separation - however US market will "prefer" more "bass".
On the new Birmeister in the new S, and to be expanded throughout the product lineup on a 2-3 schedule going foward - awesome separation/imaging and awesome and clean "bass".
Old Dec 20, 2013 | 08:46 PM
Nanook's Avatar
Modest hardware upgrade for asking price no ?
Old Dec 22, 2013 | 05:58 AM
GoldFeather's Avatar
2005 Honda S2000, 2013 ML350 BlueTEC
It appears that an undocumented feature, at least in the 2013 model, is that the system is only able to address a maximum card size of 64 GB. It took a good bit of playing around (and frustration) on my part to figure this out -- my dealer could not figure out why the 128 GB card didn't work. Once I put the same files on a 64 GB card everything worked fine.
