2014 ML HEADLIGHT CONDENSATION Problem
Old Dec 12, 2013 | 12:03 PM
Designo27's Avatar
2014 ml350 Bluetech
Exclamation 2014 ML HEADLIGHT CONDENSATION Problem
Hi all,
I am new to this forum and recently joined. I pre-ordered a 2014 ML earlier in the summer and received my car not too long ago. The car has the Bi-xenon Headlight package.
The car is brand new. I drove it in the warmer temps in September and then I had to travel. The car was parked in the garage . When I returned, I took the car out and every single time I take it out, condensation starts to appear in both front headlights.
The headlights are on during this time, and it starts to appear shortly after staying on. The colder the temp is outside, the faster the condensation appears inside. (its always on the inside ofcourse)
I was wondering if any one else with the ML 2012-2014 has had this issue or heard of it , and how it was dealt with.
I really appreciate your help on this guys. The car is brand new and still under 1000 km !
Old Dec 12, 2013 | 12:14 PM
Designo27's Avatar
2014 ml350 Bluetech
Some photos
Here are some photos attached.
Attached Thumbnails 2014 ML HEADLIGHT CONDENSATION Problem-photo-1-1-.jpg   2014 ML HEADLIGHT CONDENSATION Problem-photo-2-1-.jpg   2014 ML HEADLIGHT CONDENSATION Problem-photo-1.jpg   2014 ML HEADLIGHT CONDENSATION Problem-photo-4-1-.jpg   2014 ML HEADLIGHT CONDENSATION Problem-photo-3-1-.jpg
Old Dec 12, 2013 | 05:40 PM
emran's Avatar
ML 350 Bluetech 2013 Loving it!
I am sorry to say I saw that last week after washing the car.It went away. I had the same issue with my rear lights on my E240 when I had it 5 years ago.
My concern is that will this gradually increase and corrode the inside and get dull. Is this a warranty replacement issue ?
Old Dec 12, 2013 | 06:32 PM
Nanook's Avatar
'18 GLE63S AMG /'19 PORSCHE TURBO S / '09 CORVETTE ZR1 /'14 LEXUS RX350/'16 RAV4 Ltd
I believe the dealer/MB will tell you incidental moisture in the headlamp is normal and it will disperse with time. Most headlamps assemblies have venting properties/devices that allow condensation and moisture to escape....good luck ..it may actually correct itself..
Old Dec 16, 2013 | 07:06 PM
Designo27's Avatar
2014 ml350 Bluetech
Thanks for the feedback guys. Unfortunately its getting worse. I have made an appointment and will be taking the car to the dealership.
Will keep you guys posted.
In the meantime, here attached are some more pics.
Attached Thumbnails 2014 ML HEADLIGHT CONDENSATION Problem-photo-2-2-.jpg   2014 ML HEADLIGHT CONDENSATION Problem-photo-2-3-.jpg
Old Dec 16, 2013 | 08:48 PM
Chasvs's Avatar
ML350 Bluetec
Headlight condensation is mentioned in the owners Manual. It's not unnatural. If yours is excessive, you may have a bad O ring on one or more of the access covers for bulb replacement.
Old Dec 17, 2013 | 07:10 AM
ChrisMclass's Avatar
2014 MB ML63 AMG
If you start to see water puddling in the assembly then you need to worry. I've not had a problem with my ML but the first night I brought home my Acadia it was raining and humidity had creeped into my headlamp assembly, but hasn't happened since.
Old Dec 17, 2013 | 12:00 PM
buckeyewalt's Avatar
E63,,,not any more,,,BMW X5 50i
I had this issue with my E63. Took it to the dealer and they drilled (not to my approval, unless I didn't want the condensation to re-appear) a very, very small hole in the corner of the plastic cover. I can't believe that all of the condensation went away after a few days. No water came in during rain either.
Old Dec 17, 2013 | 04:58 PM
EVOII_Racer's Avatar
Mercedes Evo II
What thats crazzy Stuff!!
I don't have this problem on my ml main headlights but the "bottom runing day light" I am also experiencing condensation (after I wash the ml)
You for sure have a major issue here my main 'intelligent mb headlights' don't have this problem, that's way too extensive!
Old Dec 17, 2013 | 08:31 PM
Yep, I agree with the crazy stuff. I really didn't want them to do it in the first place, but they said that's what the factory said to do. Mind you, this was 2007, but the hole were very small and placed in the back of the light. You couldn't see them unless you were looking for it. Would I let them do it again/now....NO! Mine had heavy condensation and that was the fix at the time. I remember that there was an issue with a seal or something, but hey, it worked for my particular vehicle at the time!
