Supersprint's Mercedes-Benz ML63 AMG R&D
Old Jan 20, 2014 | 03:00 PM
Supersprint-USA's Avatar
Former Vendor of MBWorld
This article is from Supersprint Official Research & Development Blog - Supersprint Labs where we take you inside Supersprint's R&D effort on various cars, explaning in full details the processes involved in crafting our world renowned exhaust systems.
**For pricing information, send us a PM or contact your local dealer.
Supersprint offers the widest range of Mercedes-Benz AMG high performance exhaust systems on the market. Throughout the years, we have amassed vast experience with Mercedes’ massive naturally aspirated and supercharged V8s.
Recently, Mercedes-Benz AMG completely changed their engine development philosophy to meet ever increasing fuel consumption requirements by reducing displacement and going to twin turbocharged V8s for higher end AMG offerings. Our research & development for the ML63 was based off the hundreds of hours spent refining our exhaust for the CLS63 and E63.
Stock Exhaust
The ML63 AMG’s stock exhaust is composed of downpipes with built-in ceramic catalytic converters, a hefty center resonator and into a large, internally baffled muffler along with newly redesigned AMG tips.
The stock exhaust is divided in 2 sections:
1.Catted downpipes
2.Center resonated section with rear muffler and tips
As with all Supersprint R&D efforts, they begin on our in-house MAHA dyno on which we recorded 533.7hp and 736.2Nm. The results are slightly over factory quoted numbers of 525hp and 700Nm.
Supersprint Exhaust Development
Due to the new twin turbo 5.5 V8 from AMG, sound characteristics have changed since the 6.2 naturally aspirated V8. We set out to bring back the classic AMG V8 sound while drastically improving performance. The OEM exhaust piping diameter is 70mm and limits mid-range and high RPM performance. We tested various diameters and selected a 76mm diameter.
We engineered our exhaust configuration in 3 separate sections:
1.Downpipes
Must be installed with center pipes
2.Center pipes
Can be installed to OEM downpipes and OEM rear muffler
3.Rear muffler
Can be installed to OEM center pipes
Section 1 & 2: Downpipes & Center pipes
The OEM exhaust uses excessively restrictive ceramic catalytic converters right at the exit of the OEM turbos. We removed the OEM cats from the downpipes and replaced them with HJS metallic racing catalytic converters with much higher flow and heat management characteristics while retaining emissions compliance. The HJS cats were positioned further down the exhaust stream on the center pipes to improve turbo spooling speed, reduce backpressure and reduce exhaust gas temperatures.
The removal of the OEM cats will make the secondary O2 sensor read wrong values and will turn on the check engine light. To address this issue, it is necessary to use our optional microcats or reprogram the ECU. Along with an ECU tune and our exhaust system, upwards of 700hp is attainable.
For those that seek optimal performance gains and do not require emissions compliance, we developed catless center pipes available with or without resonators. The resonators provide a more civilized tone inside the cabin and reduce drone.
Section 3: Rear muffler
The rear muffler section was engineered and tuned upon completion of section I and II to improve the sound characteristics of the ML63 AMG and limit drone. We developed 2 variants of our rear muffler; Sport and F1 Race.
The Sport muffler is TUV approved and meets European noise regulations. The F1 race has specifically engineered muffler internals and Helmholtz chambers to increase high RPM sound while limiting drone and resonance. The muffler was designed to be fitted with Supersprint 4x120x80mm tips or the OEM AMG tips. Both mufflers are installed using slip-on joints and do not require welding.
Performance
Stock
Horsepower 533,7 Hp @ 5505 rpm
Torque 736,2 Nm @ 4365 rpm
Supersprint:
- Downpipe kit (replaces catalytic converter) 849411
- Centre pipes + catalytic converters kit right – left 849423
- Rear exhaust 849404
Horsepower 565,5 Hp @ 5695 rpm
Torque 757,9 Nm @ 3770 rpm
Sound
Old Jan 21, 2014 | 06:03 AM
ChrisMclass's Avatar
2014 MB ML63 AMG
Fellas you did a fantastic job improving the sound of the ML. Bravo!
Is the muffler used on the truck in the video a Sport or F1 Race?
Old Jan 21, 2014 | 04:49 PM
answer
Thanks Supersprint used the sport muffler in the video.
Old Jan 21, 2014 | 04:50 PM
We currently offer special prices for all MBworld members. Call us at 877-691-2825.
Old Feb 4, 2014 | 05:35 PM
We are currently running sales on all ML63 AMG parts. PM us or give us a call at 877-691-2825
Old Feb 11, 2014 | 09:36 AM
PM us or give us a call for information on prices, stock availability and any other questions on the featured system.
Old Feb 17, 2014 | 03:54 PM
Special prices on all orders and pre-orders until March 1st. PM us or call us at 877-691-2825.
