Widest Tire for AMG 20's with 9" rim
My research in preparation for the replacement focused on finding the widest tread possible. For anything that was recommended for the 9" rim, the tread width was about 9". Going to a 295/45 would give me just over 10", but a 9 1/2 rim was the minimum recommended. The 305/50 would also give me a solid 10", but would raise the truck almost 1 1/2" but with a 9" rim. I've put taller tires on my MLs before, but did notice the handling was slightly degraded. So, when I found the DWS in 275/45 had a 10" tread on 9" rims, and was reviewed as an excellent rain tire, my search was over.
After only a few days and no heavy downpours, I can only say the tires look very good. The wheelwell is definitely fuller than before. The ride and handling is better than before (although after 27,000 miles, the original tires would have been degraded to some extent). The height increase is about 1/4" or less, so it is not noticeable. Discount Tire had to ship in a set (virtually no one carries the 20" tires in stock, I found), but it only took two days. The price of about $250 was about the same as Tire Rack and other stores, so I was $1300+ out the door with a replacement against future sidewall rips should I venture out onto the Ford Shale again. So far, so good.
