ML350 BT Mid-section rumbling/grating noise
Initially I thought this was a wheel bearing but the noise doesn't vary when turning in either direction and the sound seems to be coming from under the centre console between the seats (vary hard to pin it down the a specific location.
Dealer looked at this during a recent service and says it could be a UV joint on the prop shaft or Transfer box problem, going in for more intensive investigations for a couple of days next week.
Anyone had a similar experience? Anyone with thoughts on what it could be?
All suggestions gratefully received!
If your getting a slight humming sound and a buzzing feeling through the steering wheels as you feather the throttle on and off....it probably is the differential.
