A question about interior lighting for 2014 ML350 US
The front footwell lights are intermittent too. Sometimes they're one when I'm driving at night (albeit dim), and sometimes they're not on at all.
The footwells are dim at times, and otherwise completely off. Will ask dealer as well. Will try and get her in before the holidays as I plan to retrofit the HK speakers I got at a pick and pull and eBay over the Christmas holiday too. That will be a fun project
out speakers, and then I'll re-evaluate from there whether or not I want to keep adding. I'm curious how the mid-range speakers in the front doors mount though -- I haven't picked those up yet (pn # 231-820-07-02). I see the hole in the speaker grille for it, but don't see how it would fit into the door panel.
See the picture below from a W166 with the HK system -- that's the HK woofer, but don't see where the mid-range speaker would fit. (Let alone the larger problem of the wiring not being there for the speaker since I don't have the HK wiring harness).
Door removal seems straightforward based on some YT videos, so I imagine it will be plug and play as soon as I get them off. Just have to be careful and not break the clips. And thank god these speakers are Torx screws and not riveted in like the W204 HK system in.
Crazy, right?
And 1000% agree on the next one. Have the bucket list already ready, but enjoying this one for now!
I've officially swapped out all the door speakers with their HK counterparts. Only speakers I didn't do are the D pillar ones. Can I ask you a huge favor when you get a chance though? The 2 mid-range speakers in the front doors sound a bit overpowering. When I installed them there was a foam piece there that blocked the grill on the door. I cut it out carefully as I assumed it was part #18 here in the diagram for cars with the non-HK system (to cover up a blank hole) - https://www.mbdirectparts.com/auto-p...ront-door-scat
I'm curious in your truck, if you shine a light in the speaker grill on the door, with the top hole, can you SEE the mid-range speaker, or is it behind the foam piece I cut out? (Meaning you'd only see the foam piece). I'll know how to proceed accordingly then
Thanks!
Thanks!
I'll check and get back to you
Yeah, there's where the mid-range speaker is. In the ML's that didnt have the HK system, the interior panel in the door frame and the speaker grill are the same (meaning there's the mounting holes, and the hole in the grille) for the HK ML's. It fits right in as it should -- just curious on yours if you can see the actual mid-range speaker when looking thru the grille like you can the woofer.
Again, no rush, just curious! Thanks Dr!
here is what is part of code 876 (as defined as INTERIOR LIGHT ASSEMBLY)
1) Under wood dash lights, to the left of the steering wheel, to the right of the steering wheel all the way until the right AC Vent (again, see thread link)
2) Door under wood dash (same as #1, 3 colors)
3) rear door courtesy lights (Red/white, w/o 876 only front doors have it **i think this might be default in the GLE 350**)
4) Under front passenger seat lights (see the thread link i sent with the picture, you'll see everything in those pictures)
5) cup holder lights, (at the rear of the cup holder, this is not obvious). If you have the heated/cooled cups, you'll see the whole cupholder illuminated (Red: heated, blue: cooling, solar: nothing)
6) Lighted Vent controls of all AC vents in the front, maybe in the back too (cant definitively say)
7) illuminated door sills (Front only, Mercedes-Benz lights up)
MBUSA prices this option for $310 extra, granted if you do SPC (special order) or if you find it on a CPO you want, or a new one (GLE 350 has this w/P2, i've seen one model with 876 w/o P2 package)
Sucks it isnt standard, but hopefully if you chose the GLE going forward again, make sure you check and make sure
