Retrofit GLE Tail Lights?
Old Nov 2, 2016 | 06:31 AM
tlovidiu's Avatar
Mercedes-Benz W211 - E220 CDI
Hi Guys,
Do know if it is possible to install te new GLE tail lights just by plugging them in?
Old Nov 3, 2016 | 10:01 AM
snaoum's Avatar
2012 ML350
Interested in this also. updating the ML with few GLE items would really make the ML a bit more personal.
Old Nov 3, 2016 | 11:08 PM
Isawelvis's Avatar
Veteran: Air Force
, 2023 BMW X4, 1991 190E
Tail lights
I have a 2015Ml. How are the tail lights different on the GLE. Aren't both led type tail lights. Also, I asked on this site in an earlier email about European ML taillights. Overthere the turn signals must be yellow/amber. Personally, I think they are easier to see at night. Anyone know what they look like on Euro models, maybe the same way in Canada not sure.
Old Dec 5, 2016 | 09:25 PM
snaoum's Avatar
2012 ML350
Any word on if GLE tails lights would work on a ML?
Old Dec 6, 2016 | 11:20 AM
350MH83's Avatar
2017 GLS 350d
I am sure they will work. It is the same assembly altogether, just the outside shape is slightly updated.
Old Dec 6, 2016 | 12:41 PM
snaoum's Avatar
2012 ML350
Can we assume it will be plug and play? Both are LED right? I have a 2012 ML but I believe it is LED but I could be wrong.
Old Dec 6, 2016 | 01:08 PM
nookie's Avatar
GLE350d, Porsche TE
Not plug N play, Connectors are different. you'll be dealing with a bulb warning message for tail/signal, so some resistors may be needed unless dealer can program the BCM with an LED option plus some wiring changes (if that exists in any ML model) pics attached.
Attached Thumbnails Retrofit GLE Tail Lights?-ml.jpg   Retrofit GLE Tail Lights?-gle.jpg   Retrofit GLE Tail Lights?-gle1.jpg
Old Dec 9, 2016 | 04:08 AM
Hoplatani's Avatar
Ml350 bluetech
GLE Tail Lights
I bought one tail light on Ebay, I had the same info from my dealer, you have to reprogram the BCM but no body is gonna do it because its prohibited from MB.
Ill try to convince someone here, and ill let you know if it works.
Old Dec 9, 2016 | 01:03 PM
snaoum's Avatar
2012 ML350
Instead of programming the BCM/SAM, perhaps making wiring changes and moving pins around and adding resistors would work if we are able to grab a harness/plug that goes into the taillight.
Old Dec 17, 2016 | 07:57 PM
Isawelvis's Avatar
Veteran: Air Force
tail lights
Not sure how the GLE lights are different but I think ML550 and ML63 taillights are different than regular ML350. These should be a direct replacement, plug and play
Old Dec 20, 2016 | 01:43 AM
jtorrebl's Avatar
2025 Panamera GTS
they are not different from the regular ml350. I had a 2012 ML550 and its exactly the same
Old Dec 20, 2016 | 12:28 PM
drwolf's Avatar
2020 GLE350 2020 Toyota Rav4H AWD XLE
from looking at the GLE from a distance the assembly looks the same for the most part, i guess its the LEDs that make a difference
Old Feb 27, 2017 | 03:50 AM
liviumarcu_28's Avatar
ml 164
I did it
It is possible to put gle tail lights on the w166 ml. I did it a few weeks ago and waited to tell because I wanted to test the change and make sure it works in time. It is not simple but it can be done in your own garage with a bit of work. The only thing that does not work is the reverse light. On the ML it is in the middle but on the gle it is on the sides so you would have to put wires going from inside the back door to the lights on the sides. I did not care very much about reverse so I did not go there but I can tell you that everything else works. Mechanically the side lights fit almost perfectly. There was just a minor adjustment I had to make with a cutter, about two millimeters of plastic from a spacer on the upper side of the tail light. Lets go now to the electrical issue. The tail lights I put on were bought from my local dealer, three of them, and from ebay the fourth. Initially I bought one from ebay to test the mecanical fit and some electrical issues. I also bought the plugs for the two side lights ( the ones on the body of the car, not the door) from the local dealer, 4 dolars a piece. What you also need to know is that you will need four 24 W resistors made by Osram. I got them from a friend that does electrical repairs but I m sure you can easily find them. The resistors will have to be connected on the plus and minus of the brake lights ( One on each side , to use the surplus of power the incandescent lights of the ML are provided and the leds don t need) and than connected to the metal parts close to the tail lights with a screw so the heat disipates to the cars body. The main issue I had was how to reposition the pins from the ML plug inside the plug of the Gle. I did some tests on the new tail lights and wrote down what lights up what. The input of the wires of the Ml I easily found on another topic here on the forum and so I could reposition the pins in the new plug. To reposition you only have to open the plug and pull them out. The plugs for the door lights fit with just a bit of cutter work. As the Osram resistors come with friendly user connectors, the hardest part of this swap is, in my opinion, getting the pins repositioning right. I hope I covered the whole process.
Old Feb 27, 2017 | 04:40 AM
AkaSigFreak's Avatar
E350 Sport/ML350RWD
So...the lights don't fit and they don't work properly. Reverse lights are kinda important and when it comes to something as important as Brake Lights- don't mess with the wiring. If you are ever in an accident- you will most likely get the crap sued out of you.
Old Feb 27, 2017 | 11:04 AM
drwolf's Avatar
or he could put the backup noises that trucks use
Honestly the ML brake lights/reverse isnt that bad looking, i mean it follows the pattern of the old W212 (pre facelift) and that isnt that bad. When i drove the W212 (mine was facelift, no lighting package) the cool thing was backing up because it was so bright with the led reverse and brake lights that it lit up the whole area behind the car
Old May 5, 2017 | 11:14 AM
Hoplatani's Avatar
Ml350 bluetech
Can you help us with some pictures
Hi, can you please help us with some pictures, part # for the connectors, details about Osram resistors since a lot of us want to try and swap the lights?
Thank you
Old Jun 19, 2017 | 06:14 AM
ml 164
hi guys,
sorry for the late response, I was on a different email address.
I have been using the new tail lights for a few months now and there were no problems. I also wanted to have a few weeks of summer and see how thay behave with the outside temperature increase. There is no problem, but you have to make sure you screw the resistors to metal parts. I ll try to post some pictures. The lack of reverse lights was easy to replace with a light press of the brake peddal with your left foot while you reverse. the brake lights are bright enough.
Old Jun 20, 2017 | 09:50 PM
jrsmith_68's Avatar
Veteran: Army
2007 C350 2015 ML400 1968 Ford Mustang
Good to know that the lamp housings fit without much trouble. A while ago I changed the incandescent brake light bulb to a super bright LED, mostly because I wanted the faster response (safety) of the LED. However I wasn't keen on adding a resistor because if the LED ever did fail, you would never know it and have no brake lights, like in a old car! Anyway, with Vediamo, I was able to change the current threshold for the warning so that it would be compatible with LEDs and still get the warning if there was 0 current flow. I assume this would also work with the GLE LEDs if anyone has Vediamo. I could take a screen capture of the parameter I changed if anyone needs it.
Old Jun 21, 2017 | 01:38 AM
Rainers's Avatar
You can buy backup lights that fit on your trail hitch and act like reverse lights.
Old Dec 1, 2017 | 04:14 AM
Paul ML350's Avatar
Ml350
hi guys,
hi
why didn't you proceed with the reverse light like you did with the break like? It doesn't work? The reverse light at gle lamp is Led, isn't? And at Ml is bulb light.... it is necessary to put That rezistors also on reverse light. Am i wright?
Old May 5, 2018 | 11:53 PM
Evgenievich's Avatar
gle
Can anyone post with wire diagram with pin numbers?
Old May 6, 2018 | 06:19 AM
peter2772000's Avatar
2012 X6 35i Sport, 2013 ML 350 BT, 2019 4Runner TRD Pro, 2020 CRV-AWD
Personally, I don't understand what the difference is between the ML & GLE tail lights, other than the fact that the clear LED strip is in a different location.....
Old May 7, 2018 | 01:18 PM
drwolf's Avatar
its not just that, the reverse lamp was completely re-positioned. So many ML/GL drivers are asking if they can retrofit their front and back lights, its crazy..
Old May 7, 2018 | 06:35 PM
pgeller's Avatar
2014 ML350 Bluetec
Check CKM Car Design website.
pg
Old May 7, 2018 | 07:27 PM
pg
Wow, a lot of stuff for our MLs
