Help with 2012 ML350 Bluetec Upper Limit Reached
PULLING CODE 150300 code with Snap-On scanner (Hot Film Upper Limit Reached)
Replaced: Both MAF sensors along with gasket, MAP sensor, both air filter. All OEM part. Re-adapt both sensors with Snap-On Scanner.
Vehicle is running great. However I can't clear the check engine light. It's still show the same code.
Please help if you have/had similar problem or experience with it.
Thanks in advance.
Ledvu1
