Tire Rotation. Directions and Mileage.
Hi All,
Couldn't find any recent posts.
Quick questions: how to properly rotate tires on ML350 and how often ?
Tires are Pirelli 265/45/20
Thank you in advance.
2014 ML350 2w, 2017 GLS550, 1967 Pontiac GTO 4 sp
From the 2014 OM. Front to back on same side so that rotation direction stays the same. Every 3k to 6k.
If your vehicle's tire configuration allows, you
can rotate the wheels according to the
intervals in the tire manufacturer's warranty
book in your vehicle documents. If no
warranty book is available, the tires should be
rotated every 3,000 to 6,000 miles (5,000 to
10,000 km), or earlier if tire wear requires. Do
not change the direction of wheel rotation.
Clean the contact surfaces of the wheel and
the brake disc thoroughly every time a wheel
is rotated. Check the tire pressure and, if
necessary, restart the tire pressure loss
warning system or the tire pressure monitor.
