Staggered vs non-staggered wheel
Then there's your choice of wheels... despite pics of them on SUVs, I highly doubt that Rohana RC10s are able to safely support a 5500+ lb truck (if someone tells you that they are, ask for the specs including their rated weight IN WRITING - you're looking for 2200 lbs per wheel). Then you probably won't be able to find tires with a high enough load rating (108 or higher) in those sizes, the ride would be harsher than my track rat with no suspension travel and solid bushings, the tires would be noisy enough to be uncomfortable at 35 mph, and the rims would bend or crack the moment you come within 20 yards of a 1/2" pothole.
I love aftermerket rims and have had several sets for every single vehicle I've ever owned, but for both of my SUVs, I chose quality 20" wheels that are made for SUVs and are either fully forged or heat treated (tempered), and both the tires AND RIMS are rated to support over 2200 lbs per wheel. Just saying... there's more to it than just looking cool. You might want to rethink this and reevaluate whether looking like a baller is worth the risks and downsides with your particular setup.
And, personally I think 22s would look funny with the small-ish brakes on a 350, but that's a matter of taste so to each their own.
And, just an FYI, weight is not equally distributed across all four wheels even in a static condition, never mind during braking or cornering. As for the weight of the ML, the ~5000 lb curb weight is for a base RWD model with no optional equipment, cargo or occupants. Once you load up the car with groceries, you and a pasenger, you're already at 5500 lbs.
P.S. I just had a look (somethign didn't look right as I was looking into tires for a customer's Cayenne the other day)... the 265/35-22 Conti DWS 06 is only a 102 load rated tire (1875 lbs). Are you sure you're looking at the right one - the 265/40 has a 106 load rating?
P.P.S. Here's an intersting and current read for you: https://mbworld.org/forums/c63-amg-w...warehouse.html
