W166 Auxiliary Battery information
Old Aug 14, 2023 | 01:10 PM
JCM_MB's Avatar
2008 E350, 2012 ML350, 2014 E350, 2015 ML350
Unfortunately nothing for those codes. That is the part number for the "small battery" , and that Q006 I have seen with Q005, but I do not think is related to date.
Nothing stamped on the plastic casing around it?
Old Aug 14, 2023 | 01:17 PM
mike919's Avatar
86 190E 2.3, 2014 ML350 Bluetec
Maybe this top number, 22/12/02 = 2022 December 2nd?
Old Aug 14, 2023 | 01:29 PM
JCM_MB's Avatar
It depends on the manufacturer. Likely 2022 for the year, but the next 4 digits could be a month or a week. Never seen the day listed. If it were 223202, I would guess 2022, week 32. At this point I think the year is what matters.
Old Aug 14, 2023 | 01:41 PM
mike919's Avatar
Either way it's in good shape, my smart charger shows it at 100% charge. Curious to see what the original is at.
Old Oct 20, 2023 | 08:10 PM
tonyl13's Avatar
ml350 bluetec
Showed the BatteryPlus person this in Tucson today (great short cut for AUX bat) they installed main & Aux battery's (Duracell) for $330 total
Old Oct 21, 2023 | 08:53 AM
chassis's Avatar
2017 GLE350 4MATIC
Good information in this thread.
Link here to W166 GLE350 4MATIC non-start/stop aux battery replacement: https://mbworld.org/forums/gle-class...ml#post8540108
No coding or battery registration required. No battery maintainer required. Same goes for the main 12V starting battery under the front passenger seat.
Old Oct 23, 2023 | 11:11 PM
  #32
Terry WM's Avatar
2002 ML 500
Battery is nothing special
You can buys these from most battery or electronic places
It is a Sealed Lead Acid, 12 volt, 1.2 amp hour. A larger amp hour will work as long as it physically fits.
Old Oct 24, 2023 | 03:08 PM
  #33
bha1's Avatar
2010 g
Yes definitely do NOT buy the MB dealer battery. It's just a regular battery with their label slapped on it, and is way more expensive.
I am the GTA (Toronto) and found these online in Burlington. Free pickup. So depending where you live you can likely find something similar.
As mentioned, anything the same size will fit (even if larger capacity) but I'm not sure you need anything with a larger capacity.
UB1213 - 12V 1.3Ah Universal Battery - D5738 | batteryspecialist.ca
I believe the website I linked shows larger capacity batteries with similar size somewhere on their web page.
This one is $13 CAD ($10 US) so they are really cheap compared to the MB ones! I have installed 3 now in different cars (going back about 7 years) and they work perfectly with no failures yet!
Old Sep 10, 2025 | 05:21 PM
  #34
eddieo45's Avatar
me: 2015 SL400 & 2015 ML400; wife: 2022 GLC Coupe; daughter: 2017 GLC SUV
This thread is nearly 8 years old! Perfect for my 10 year old W166!! First I have a question: what exactly does the auxiliary battery power? As for the replacement battery it seems you can pay $60 (or more) for an A001 982 27 08, or $27 for an ETX14, or even $7 for a UB1213/D5730, but THIS ONE for $15 shipped shows up as compatible in most of those searches. That's the one I'm going with.
Old Sep 10, 2025 | 06:10 PM
  #35
JCM_MB's Avatar
Are you sure that is the auxiliary battery on your W166? Depending on the years it can be the "mini/alarm" type of battery, or the "midsize/motorcycle" type of battery (AUX14)
Old Sep 11, 2025 | 07:10 AM
  #36
bobofthenorth's Avatar
2013 ML350 Bluetec
Good luck with that - I hope it works better for you than it did for me. I replaced mine with something sourced off Amazon and ended up with the red letter "drive directly to dealer, do not change gears" message. Message multiple times - one prolonged incident in a hotel parking lot where I thought it was tow-time. When I got home I realized that the "compartment" for that toy battery is actually just a bracket in the corner of a much larger battery box that would house a real motorcycle or grain auger battery so I swapped out the micro batt for a real battery. Not a hint of trouble since.
Old Sep 11, 2025 | 09:54 AM
  #37
chassis's Avatar
2017 GLE350 4MATIC
DIRECT SELECT electronic transmission gear selection.
Old Sep 11, 2025 | 04:22 PM
  #38
JCM_MB's Avatar
Here two different W166 vehicles, both batteries are possible
Old Sep 11, 2025 | 06:52 PM
  #39
2013 ML350 Bluetec
Exactly. It looks like there was a real battery used at one point and then some genius engineer decided to downsize to that ridiculous thing that would be barely adequate to power a small RC truck. Chuck the toy battery in the bush. Put a real battery in the battery box that is already there. The real battery will cost less than a MB toy battery and your troubles will go away. The only challenge with the swap is that you won't have a factory hold down that works on the real battery. I used a couple of zip ties but you might come up with something more elegant.
Old Sep 12, 2025 | 07:49 AM
  #40
eddieo45's Avatar
Does that mean the paddle shifters??
Old Sep 12, 2025 | 08:28 AM
  #41
JCM_MB's Avatar
The transmission shifter is on the column: DIRECT SELECT
Old Sep 13, 2025 | 09:51 AM
  #42
2013 ML350 Bluetec
No. Your transmission uses a little electronic servo on the outside of the transmission housing to shift P-R-D. The forum wisdom believes this module is powered directly by the auxiliary battery. I don't think that is true but a failing auxiliary battery clearly does impact those shifts.
Old Oct 11, 2025 | 04:39 PM
  #43
eddieo45's Avatar
https://www.youtube.com/watch?v=lWKRueYJRJQ
https://www.youtube.com/watch?v=Jdgwt9dpwSc
Just my luck: I bought the small battery and my vehicle has the large one; anyone have that part number?
Old Oct 11, 2025 | 07:00 PM
  #44
2013 ML350 Bluetec
Its just a 12v battery. Measure it and buy one that fits.
Old Oct 11, 2025 | 07:54 PM
  #45
JCM_MB's Avatar
I assume you already looked in the back/trunk.
The "medium size" battery is a AUX14 AGM 12V 12Ah 200CCA vented battery.
For example, https://www.fcpeuro.com/products/mer...mer-0009829308
Any reputable brand will do if the minimum specs above are satisfied. You may find 14Ah, that will be fine as well.
Old Nov 4, 2025 | 09:31 AM
  #46
eddieo45's Avatar
So I initiated the return of the SLA battery and the seller refunded my money without requiring me to send the battery back. Now I'm considering using it instead of buying the $180 "vented" battery. I'm mostly motivated by laziness, given that I was able to access the battery location in about ten minutes, but it looked to me that the actual removal/replacement of the battery might add an hour or more. Could I possibly wire the "mini" battery in without removing the existing battery?
Old Nov 4, 2025 | 09:51 AM
  #47
rapidoxidation's Avatar
2013 ML350 Bluetec
Maybe, but why not just do the job correctly?
Old Nov 4, 2025 | 10:00 AM
  #48
eddieo45's Avatar
the answer to your question is right there in my post; 12v=12v so why not make my life easier??
Old Nov 4, 2025 | 10:21 AM
  #49
2013 ML350 Bluetec
The answer may be "right there" but, if so, I don't see it either. Your car, your shop, your way. But there's no substitute for doing it right once. Its amazing how when there isn't enough time (or energy) to do it right the first time, we'll still find the time and energy to do it over later. I'm 67 years old and i still haven't fully accepted that wisdom so I completely understand why you may not as well.
The right fix is pull the defective battery and replace it with a good new one.
Old Nov 4, 2025 | 10:54 AM
  #50
JCM_MB's Avatar
If you think that two batteries have the same functionality because 12V = 12V, you have not evaluated the two batteries closely.
The little battery is rated at 1.2Ah, and the medium-sized battery is rated at 12Ah. That is a factor of 10. Additionally, I have not explored the CCA of each battery type either.
Also, the MB vehicles are very sensitive to voltage levels and available power (juice). A low voltage battery can trigger all kind of errors. Some technicians start chasing the error messages instead of checking the batteries, charge/replace them and money is thrown away for no reason.
The cherry on the cake is transmission control modules corrupted because of a low voltage during the computer module's booting/shutdown process. It happens to laptop/desktop as well with corrupted BIOS. Some technician replace TCM, plus coding plus $$$. The MB "hackers out there" reflash the TCM, and problem solved with minimal cost but only a few know how to do it (defintely not me). Summary: keep your batteries charged and healthy
