P1CCF Engine Fault Code
Old Jan 31, 2018 | 01:02 AM
AlohaPaul's Avatar
ML350
My 2013 ML350 is showing an engine fault P1CCF. I can't find this code anywhere on line. Anyone?
Old Jan 31, 2018 | 10:47 AM
pcy's Avatar
pcy
'14 ML350, '13 C220 CDI, '07 C280, '98 ML320
If I were you, I'd erase the codes and see if it comes back.
Old Jul 3, 2018 | 07:11 PM
randy19's Avatar
acura rsx
What was the code?
Did you eventually found out what the P1CCF code was? What was the fix and hiw much?
Old Dec 3, 2018 | 05:55 PM
yavuz's Avatar
glk350
My GLK350 g'ves same signal. Did you find out what was it
Old Dec 4, 2018 | 05:52 PM
randy19's Avatar
acura rsx
finally the dealership able to pinpoint it to a faulty fuel pump. It was replaced under extended warranty. No check engine since. If parts are available you get it same day. Mine took 3 waiting for the part.
