2014 ML550 wheels
Old Mar 21, 2018 | 12:48 AM
C63sCab4me's Avatar
AMG GT-S, GLC43 AMG, ML550
2014 ML550 wheels
I want to upgrade my 19" factory rims with aftermarket +1 or +2 size.. will Ml350 wheels work on my 550? Tire Rack has no selection for 550 specific rims but lots for a 350 and 63.
After speaking directly to one of their experts" they cannot confirm if they will as they have not tried it...they also mentioned that the 550 calipers and rotors are larger than the 350's and the offset might also be different. I asked if the rims from a ML63 would work and they cannot confirm that either....does any out there know? Other on line retailers show the rims work on all the ML models.
Old Mar 29, 2018 | 11:14 PM
Isawelvis's Avatar
Veteran: Air Force
, 2023 BMW X4, 1991 190E
Yes you can fit ML 350 wheels on a ML550. I have currently have GL wheels on my ML. They are 1/2 wider than what came on my ML. Also, if you search for used MLs especially on the Mercedes Benz CPO sites they always have a picture of the door frame showing the wheel size that came on the car. ML550 came standard with 19" and had option for 20", just like ML350. The only thing I think is different is the the ML550 may have had a wider wheel like the ML350 but not sure. Since the ML550 came standard with 19" wheel we know that 19 inch wheels will fit. I do know that the 550s have drilled rotors (ie holes in them) whereas ML350 are does not have holes in them, not sure about the size of the rotors though. I just checked the inside door frame and my 2015 ML350 came with 8J X19 but like I said I am running 8.5 and 19.
Old Mar 30, 2018 | 12:02 AM
C63sCab4me's Avatar
Thank you for your response. I am planning to go 22”
regards
