Oversized tires?
Old May 11, 2018 | 05:54 PM
MBspdfrk's Avatar
2014 ML 350 Bluetec
Oversized tires?
can someone tell me what the biggest tire that fits on stock rims is?
Would GL550 wheel/tires fit?
thanks.
Old May 11, 2018 | 07:50 PM
peter2772000's Avatar
2012 X6 35i Sport, 2013 ML 350 BT, 2019 4Runner TRD Pro, 2020 CRV-AWD
First off, you need to know what your rim size is, diameter and width.
On our ML, I'm running aftermarket 20" x 10.5" with a 40mm offset along with 295/40R 20 tires. Rear's been dropped almost 2". No rubbing anywhere.
But, if I had to do it all over again, I'd look for a 10" wide rim with a 45mm offset so as to tuck the tires into the wheel-wells ever so slightly.
Old May 23, 2018 | 04:37 AM
Jesse7's Avatar
ML350
Can 22x11 fit in the rear of a 2015 ML350?
I’m thinking of purchasing some aftermarket wheels and I was just curious to know if anyone tried to install 22x10 in the front and 22x11 in the rear ... I had a 2013 BMW X5 xdrive50i and I was able to install 22x11 in the front and 22x12 in the rear ... I am not planning to lower the ML .... Thanks In Advance
Old Jul 1, 2018 | 10:06 PM
TwinTurboTim's Avatar
2006 CL65
I am running 275 55 20 on my ML63 knock off wheels. They dont rub but throw a code in the transmission for "Implausible Tire Size" so your check engine light will be on.
Old Jul 1, 2018 | 10:21 PM
Jesse7's Avatar
ML350
Thanks Turbo Tim !!
You have already rated this thread Rating: Thread Rating: 1 votes, 1.00 average.
