Advice on driver door wood trim replacement 13 ml550
Old Jun 23, 2018 | 10:08 PM
Andynv's Avatar
2013 ML 550
i am new to the forum, and a new owner of a low mile 2013 ML550. Although I have no idea how this happened, the driver side wood trim was cracked, however the seller bought a new replacement. I will be installing this with the help of a neighbor who is a very proficient mechanic. Has anyone done this job, and if so do you have any advice or recommendations to make the job easier? My neighbor said there is a special removal tool to make the job easier but I have never attempted anything like this so it is a bit intimidating. Thanks in advance.
Old Jun 24, 2018 | 07:07 AM
termite's Avatar
2013 E350 wagon cuprite brown; sold:2014 ML63; R500 Saks Edition; R500; more W124s than I can count
I just did this yesterday on my ML63 and it is not a bad job. I changed over from stock burl to the flat finish wood. You do need a set a trim removal tools so that you don’t butcher your door panels. There are YouTube videos for taking off both front and back door panels. The rears have two t30 bolts each and the fronts, just one. The wood trim is held on by t10’s, screwed from the inside of the panel. Oddly enough, the harness plugs are color coded, so you really can’t go wrong.
Old Jun 24, 2018 | 12:24 PM
Andynv's Avatar
2013 ML 550
Thanks termite, this helps a lot. Are the trim removal tools basically generic in size? Me neighbor said he had a set, just want to make sure they will work.
Old Jun 24, 2018 | 06:43 PM
DanD.'s Avatar
2018 GLC 4MATIC
Can you share Youtube link on panels removal?
I was searching and searching for months.
I have something rattling inside want to take it off and look.
Old Jun 24, 2018 | 08:00 PM
termite's Avatar
Old Jun 25, 2018 | 05:16 PM
DanD.'s Avatar
2018 GLC 4MATIC
Thank you. Big help.
Old Jun 29, 2018 | 12:05 PM
Andynv's Avatar
2013 ML 550
Ok, now I have an even bigger problem. I just received the new part yesterday from the previous owner, part number 166-720-23-22. The trim on my car is 731 burl walnut. The problem is, the new trip is brown in color, whereas my other wood trim is more reddish in color. They don’t match at all. I called the dealership where the part was ordered and they said it was the right part, and that I had an “older” car, my trim had probably faded, which is not true. Has anyone else run across this problem?
Old Jun 29, 2018 | 07:39 PM
Isawelvis's Avatar
Veteran: Air Force
, 2023 BMW X4, 1991 190E
Brown Ash?
Did you replace your wood trim with Brown Ash? If so where did you find it ? Are you also replacing the console cover. I want to replace mine with the Brown Ash.
thnks
Old Jun 30, 2018 | 12:24 PM
Andynv's Avatar
2013 ML 550
The part number I have is 166-720-23-22. I can’t tell exactly what the technical term for the color should be, but it is brown whereas the trim on my actual car is more reddish.
Old Jul 2, 2018 | 08:28 PM
Andynv's Avatar
2013 ML 550
So I spoke with the local Mercedes parts manager on Saturday, and he is going to order several of the same part numbers to see if there are any color variations. Should be interesting.
